2021+ F150 Discuss the 2021 Ford F150
Sponsored by: Real Truck
Hybrid owners please.....
Old Nov 24, 2021 | 05:00 PM
JCZhome's Avatar
JCZhome
Any of you F-150 hybrid owners pull a travel trailer yet?
What mileage are you getting, while towing a travel trailer? What is the weight of the trailer that you're towing? single axle or double axle trailer?
I am getting a hybrid and will be towing a Grand Design Momentum 21G with my CVO Harley Ultra Classic in that back. Here are the specs on the trailer I'll be towing.....it's heavy and tall so kind of like a sail in the wind...... UVW 6400 lbs, Hitch Weight 920 lbs, GVWR 9995 lbs, Length 26'11" Height 12'1" Axle Rating 5200 lbs Fresh Water Capacity 100 Gal, Grey Water Capacity 74 Gal,, Waste Water Capacity 39 Gal, LP Capacity 40 lbs, Furnace 30000 BTU https://www.granddesignrv.com/showro...floorplans/21g
Old May 19, 2022 | 09:55 AM
LittleRadio's Avatar
LittleRadio
JCZhome, can you report back on fuel economy? Speed? Distance? Elevation? Very curious, as I hope to pull a TT too this summer.
Old May 27, 2022 | 08:39 PM
xlsleeper's Avatar
xlsleeper
2nd Gear
(21 power boost crew cab 2wd) it’s a pretty big drop off when towing, I average around 23-24mpg no trailer just commuting. But most days I’m towing a 20ft utility trailer for work ranging from 5000-10000lbs (2000lb tw MAX) and as soon as you go into tow/haul mode the gas motor will not shut off unless your stopped and then add the trailer weight I average around 14-16 mpg still not horrible but after filling up at the end of the week after not using a trailer and seeing that magic 800 miles to empty it does hurt knowing you can’t achieve close to that while towing
Old Jul 4, 2022 | 06:29 PM
tkoden's Avatar
tkoden
2020 Grand Design Imagine 3000qb about 8500 lbs I usually get around 7 mpg at 65 mph about the same as my 2015 Expedition EL. 3.5L.
Old Jul 6, 2022 | 07:57 PM
wrgrimes's Avatar
wrgrimes
xlsleeper
What does you door payload sticker show? I am considering a 2wd PowerBoost Lariat mid and hoping to get to over 1800#.
Thanks,
Reid
nonrev321
30
Jul 23, 2016 07:33 AM
contramundum
21
Jan 3, 2012 12:01 AM
JohnHarris
2009 - 2014 F150
Mar 30, 2011 06:08 PM
Ibby
All Things Towing
May 3, 2006 09:41 PM
Blane
All Things Towing
May 30, 2002 04:20 PM
