Maximum Tow Capacity
Old Dec 31, 2011 | 06:45 PM
contramundum's Avatar
contramundum
I've got a 1996 F250, Manual transmission. I'm trying to find out what my maximum tow capacity for this truck is. This is the information on the drivers side door of the label...
Front GAWR 4,600
Rear GAWR 6,084
GVWR 8,800
Is 6084 lbs what my rear axle can handle? If I hook up to an empty flatbed work trailer can I put more than 6084 lbs on my trailer? If anyone knows, or can point me in the right direction to knowing, that would be appreciated. Thanks!
Old Dec 31, 2011 | 06:55 PM
427 fordman's Avatar
427 fordman
You have to figure in the capable weight hauling of the trailer axles also. 3 6k axles and you can haul quite a bit. Tongue weight is figured in there also for your weight on your rear axle. I have commercial plates on my truck, 18 ton. I haul a trailer with a 22k lb forklift on it, total weight is figured along with how much is on each axle. Basically same pickup as you, except an auto.
Old Dec 31, 2011 | 07:13 PM
contramundum
So say I have a flatbed trailer that weighs 700 lbs. and its tandem axles rated at 3500 lbs. Can I place 6000 lbs in the trailer? Or am I only allowed to place the 3500lbs of rated weight on the trailer axles? I'm trying to find out if there is a balance somewhere and if I can get away with a little more weight.
Old Dec 31, 2011 | 07:58 PM
427 fordman
If that is all the bigger the trailer is, 6k sounds like a lot for it. All the weight is going to be on the trailer tires on that size of trailer because it would have to be centered over themto keep too much off of one set. It is so small and there just won't hardly be any transferred to the truck imo. Must be small axles/ tires???
Old Dec 31, 2011 | 08:24 PM
contramundum
Thanks. Still doing more research to get proper specs on my trailer carrying load on the axles. Thanks for the replies sirs.
Old Dec 31, 2011 | 10:04 PM
bad12jr's Avatar
bad12jr
It has 2 3500 axles?
Old Jan 1, 2012 | 01:36 AM
joe_13894's Avatar
joe_13894
The max bumper pull weight is 10,000 lbs. The max combination weight depends on the axle gearing. With a 3.55 ratio the max combination weight is 15,000 and with 4.10 it is 20,000 lbs.
Old Jan 1, 2012 | 04:47 PM
IDIDieselJohn's Avatar
IDIDieselJohn
I always said, the max weight you can put on your truck, is just before the tires blow out!
Old Jan 1, 2012 | 05:43 PM
helifixer's Avatar
helifixer
never looked at the tag in my truck but this load Hay + Trailer = 21,000lbs. I hauled it from Orchard city Colorado to central Arizona.
<a href="http://s527.photobucket.com/albums/cc359/mrhelifixer/?action=view&amp;current=IMGP8026.jpg" target="_blank"><img src="http://i527.photobucket.com/albums/cc359/mrhelifixer/IMGP8026.jpg" border="0" alt="Photobucket"></a>
Old Jan 1, 2012 | 09:35 PM
contramundum
@bad12jr - Yes it has two 3500 axle trailers. I ended up taking a load of 4 tons of mulch on this trailer and the only problem I seemed to have is that I might need a higher tow hitch as the 2 1/2 inch drop I have on it now seemed liked it was too low to the ground. A little worried, but made it home safely. Thanks for the replies all.
Old Jan 1, 2012 | 09:58 PM
rusty9cab's Avatar
rusty9cab
Just flip the hitch over in the receiver. The weight of the trailer and load should level your rig out. I have to do this when I tow my 32' enclosed race trailer.
Old Jan 1, 2012 | 10:19 PM
oldbird1965's Avatar
oldbird1965
I hauled this at 25K total weight across country.
Old Jan 2, 2012 | 04:21 PM
rideracelivemx7's Avatar
rideracelivemx7
your a beast glenn...your a beast lol
Old Jan 2, 2012 | 07:40 PM
oldbird1965
haha Steve. It made a hell of a moving trailer when we moved to AZ from NE, two round trips. The beast is under the hood!
Old Jan 2, 2012 | 07:57 PM
tshrager's Avatar
tshrager
Glenn, anyone ever tell you, you don't have enough truck for that load....lol
I never get tired of seeing these trucks with big fargin trailers behind em!
