Got a question
Old Nov 22, 2021 | 04:58 PM
Mike8623's Avatar
Mike8623
Got a question
96 f250 7.3 5 speed
Which wheel is the drive wheel on the rear of our trucks,?
The drivers side or passenger side
Old Nov 22, 2021 | 06:44 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Originally Posted by Mike8623
96 f250 7.3 5 speed
Both/either. There is not one dedicated wheel that propels the vehicle. It depends on load, weight, torque input and traction.
Old Nov 22, 2021 | 06:53 PM
Mike8623's Avatar
Mike8623
So if you were only going to put one snow chain on the rear which wheel would you put it on?
Old Nov 22, 2021 | 07:02 PM
97-psd's Avatar
97-psd
Niether. Either do both or don’t do either one.
How did you end up with one snow chain?
Old Nov 23, 2021 | 02:11 AM
FinnishStroker's Avatar
FinnishStroker
Without differential locker or limited slip,the wheel that has less traction will spin loose.
So putting only one chain in open differential,will result going nowhere on slippery.
The wheel without the chain will just spin loose,unless you have a differential locker.
Shortly put..
Old Nov 23, 2021 | 05:29 AM
Mike8623's Avatar
Mike8623
So if I have it in 4 wheel drive high the one chain on the rear still won't do any good.
I live up a dirt forest service road about 5 miles. Some of it is very steep with drop offs. Sometimes there is only ice so I only put one chain on so I don't slip as much going downhill. But on coming back on the ice uphill I need just a little traction so the one chain on the front in 4 wheel drive gives me the added traction going up the hill and gives me the added stability going downhill and not sliding over the edge.
Old Nov 23, 2021 | 06:16 AM
Mike8623's Avatar
Mike8623
OK guys got one other question.
Is there a kit I can have installed by my mechanic that will lock both rear wheels when I want them locked? If so what is best one for the money, i would something reliable that works with the best bang for my dollar.
this is my last truck. We are very remote with lots of snow. We have to pay to have the forest service road plowed. Usually in winter i chain up my truck all 4 wheels and it stays that way til spring. We leave our 4runner down at the paved road and use our f250 to go back and forth to the 4runner. Then use the 4runner to do our running around.
Old Nov 23, 2021 | 08:37 AM
farmert's Avatar
farmert
Yes there are several different kinds of lockers that con be installed in the differentials. Detroit locker is one that comes to mind. Ford made what was called a limited slip. It wasn't a true locker but it helped. google axle lockers and you will get a lot of reading and products to choose from.
Old Nov 23, 2021 | 11:00 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
One chain and positive traction on one wheel IS going to break something.
What is your aversion to installing a PAIR? Lazy? It's a 5-minute ordeal.
Old Nov 23, 2021 | 11:07 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
I am not sure I would want a locker for driving on ice. I had a True Trac on ice and that was weird enough as in D with foot on the brake the tires would spin with the low stall converter, I had to put the truck into 3rd to stop that. Something to differentiate (even slightly) seems safer, but I have not driven in the climate you are in currently.
Front lockers tend to plow and want to really just go straight as I understand from my pal with a big 4x4 and tail shop.
Old Nov 23, 2021 | 03:37 PM
wkf94025's Avatar
wkf94025
... a dirt forest service road about 5 miles. Some of it is very steep with drop offs. Sometimes there is only ice.
I grew up in snow, and have driven a lot in snow and ice, sometimes very aggressively. In those conditions you described I would only run 2 chains or 4 chains. Probably 4.
Old Nov 23, 2021 | 06:45 PM
bentring's Avatar
bentring
I would be looking into something like an air locker so you can quickly and easily lock and unlock the differentials. To be honest I'm not familiar with them at all for these trucks, but from a Jeep background...
Mike8623
Nov 22, 2021 07:11 PM
smlford
Jun 11, 2016 06:25 AM
fordguy101
Aerostar
Jan 31, 2005 01:31 PM
