Dual batteries using oem parts
I searched, but could not find any completed dual battery upgrades. Pickup is a 1993 F250 with a 460.
I want to add a second battery using OEM parts so it looks OEM. I have the driver battery tray from a diesel, but don't know where to put the washer/coolant tank. Has anyone completed this upgrade using oem parts? If so, which parts did you use?
On my '96 7.3DI the wiper tank is behind the passenger battery, behind the expansion tank.
For a 460, you may want to look at an IDI setup as they had a cap on the radiator as I understand.
Thanks for the tip.
- Joe
PM me and with your number if you can accept pics via text. I will send all needed. My dually is a L95 built in 10/95 for the 1996MY. It has most, if not all updates these had available.
As I have read, some earlier 7.3DI trucks still used the 7.3IDI cooling system...which is a radiator with a cap and a separate tank for coolant.
DocThrush
Dec 27, 2012 09:51 AM
rileybrownshaw
Aug 18, 2010 07:00 PM
