96 Explorer manual / automatic trans GEM module compatibility.
Old Nov 19, 2021 | 07:49 AM
Blown 331's Avatar
Blown 331
I recently picked up a non running 1996 Explorer. It's a two-door, 4.0 pushrod engine, 4x4 with manual 5-speed transmission. It was not running. The fuel pump took care of that. But then I had no wipers or power windows or dome light. I replaced the gem module was took care of that. Now I have no four-wheel drive. I see 4x4 low activation takes input from the clutch pedal switch. I'm guessing my replacement gem module is probably from a vehicle with an automatic transmission. Could this be my issue? Do vehicles with an automatic transmission and a manual transmission require different gem modules?
Old Nov 20, 2021 | 10:35 AM
Johnny Paycheck's Avatar
Johnny Paycheck
Your issue seems to be a 2WD donor GEM.
Old Nov 20, 2021 | 10:40 AM
Blown 331's Avatar
Blown 331
Both GEMs indicate automatic 4x4 which it has. I read this was one thing that had to match, and it does.
Steve Bennett
Nov 15, 2018 08:17 PM
Spaznaut
Dec 5, 2016 11:07 AM
bikswahla
May 7, 2008 05:40 AM
cstigas
Electrical Systems/Wiring
Oct 26, 2003 11:50 AM
