Electronic Locking Axle
Old Nov 21, 2021 | 04:32 PM
  #46
wheelerfreak's Avatar
wheelerfreak
Originally Posted by CR250Bronco
The Chevy ZR2 allows lockers to be actived beyond 25 in hi 4wd, however I don’t think lockers are supposed to be used at high speed, especially if doing any amount of turning. The wheel spin difference can’t be released so it forces the inside wheel to skip (burn out) however this puts a lot of force pressure on the differential and other parts of the drive train leading up to the motor. Something has to give and if it isn’t a skipping wheel it will be the differential/transfer case/transmission that goes boom. I don’t see the use for a locked axle at speed anyways, except for straight line drag racing which most have welded differentials. Maybe if someone/you want to straight line drag race your super duty?
I have installed Detroit lockers in just about every truck I have owned, my current Ford has a rear Detroit locker with 140k miles on it, so I know it can hold up to highway driving. I will not be commuting in my SD, but will be doing a lot of driving on dirt and gravel roads were I travel faster than 25 mph and want/need a locker for that use. These roads get muddy as heck in the rain and we get a lot of snow in the winter. I want to be able to use the locker in those conditions at 40ish MPH. When the new F350 arrives I also plan on having a Detroit Truetrac installed in the front Dana 60 as soon as possible as well. I always hear people telling horror stories about lockers on the highway, especially on ice, but I haven't had any issues with mine. The only one that is sketchy is my CJ-5, but that is just about exclusively used off-road and obviously a short wheelbase.
Old Nov 21, 2021 | 04:38 PM
  #47
00t444e's Avatar
00t444e
Yeah I have had a Detroit locker in the Rear of my truck for a few years and It works great, I have put thousands of miles on it towing. I want a Truetrac for the front but they don't make one for my Dana 50, I may swap a Dana 60 in so I can install a True trac.
Old Nov 21, 2021 | 05:40 PM
  #48
Bovinerazzr's Avatar
Bovinerazzr
I said a limited slip in the front would be better than a locker I should’ve specified for general four wheeling, no way the hard core guys could get away without a locker in front.
LRCHANDLER
Apr 15, 2021 12:09 PM
302lx
1997 - 2003 F150
Dec 20, 2009 02:32 PM
farwhitenorth
Dec 6, 2005 06:49 PM
