2-2018 F450 Problems
Old Nov 17, 2021 | 06:20 PM
Chevmn56's Avatar
Chevmn56
Hello all, ill make it short, the first problem is
1. Running board on the drivers side goes up and down on its own even when the door is open. Only does it on the rear door. Is there a sensor for this???
2. I am pretty picky and clean the truck all the time inside and out. But for some reason when i first get in the truck it smells like rotten food or something. I have tore the inside of the truck apart looking for the smell, i cant find it is this a known problem, maybe the AC dont know.
Thanks for any and all advice
Old Nov 17, 2021 | 11:36 PM
brandon4's Avatar
brandon4
I seam to remember an issue with a water leak on the passenger side floor. Anyone else remember this?
Old Nov 18, 2021 | 04:00 AM
Qvan666's Avatar
Qvan666
Is the smell kind of like vinegar or acetic acid? If it is then it is possibly mold in the vent system. Since 2008 or so this has been an issue in many different vehicles.
bob
Old Nov 18, 2021 | 04:04 AM
zeroo's Avatar
zeroo
Have you changed the cab filter? How many miles on truck?
Old Nov 18, 2021 | 10:33 AM
HRTKD's Avatar
HRTKD
Pull the plastic scuff plates and see what's in the cavity below. The plates pop right up.
Old Nov 18, 2021 | 11:47 AM
klbrown's Avatar
klbrown
My memory is not what it used to be (my opinion only), but I remember experiencing
an odd smell that ended up being attributed to the cabin air filter, which could also
be a mold issue in the vent system. ??
Old Nov 18, 2021 | 12:11 PM
Chevmn56's Avatar
Chevmn56
I have but its been about a year
Chevmn56's Avatar
Chevmn56
Not sure what you are talking about, with the scuff plates?.
Old Nov 18, 2021 | 12:13 PM
Chevmn56's Avatar
Chevmn56
Well i do live in a real humid area
Old Nov 18, 2021 | 12:39 PM
Qvan666's Avatar
Qvan666
Change the filter, check behind kick panels, under seats and under door sills for mold. If that does not help (all clean) then find someone (or buy your own) with an ozone generator and give it a good blast of ozone,
bob
wbigcount
Aug 7, 2019 07:37 AM
Quick444
Jan 11, 2010 07:51 PM
Flinno18
May 10, 2005 05:55 PM
