Broken Bolt hole
Old Nov 17, 2021 | 01:36 PM
2001plt7.3's Avatar
2001plt7.3
Broken Bolt hole
I had just bought a 4 barrell cast iron ford intake. I put it in the parts washer and when I was looking it over I noticed that the valve cover bolt hole is in half, only half of the threads are left. If I had the broken piece I could Fix it back to the intake but I do not. How do I go about fixing this
Old Nov 17, 2021 | 05:46 PM
1browski's Avatar
1browski
If you can weld cast iron, fill what is left of the old hole, then build it out, and drill and tap. Only thing I can think of.
Old Nov 18, 2021 | 03:45 PM
Thunderkiss1965's Avatar
Thunderkiss1965
Permatex has a compound that you can build up the area with, then drill and tap it. I don't remember what it's called but I found it at permatex.com. They probably have several solutions there, from JB weld on up.
EDIT Cold Weld Epoxy is what you want.
arctic_driver
Mar 22, 2015 04:38 PM
Fordy Four
May 7, 2008 11:07 PM
neevnav
Apr 14, 2007 07:55 PM
blueturtle241
Oct 13, 2006 12:33 PM
hatcatz
Nov 20, 2005 08:54 PM
