05 Excursion AC/Heat issue.
Old Nov 16, 2021 | 02:18 PM
ZacCobb's Avatar
ZacCobb
During the summer, my AC wouldn't blow cold enough. I checked the freon, it was spot on. It would only blow cold when the excursion was going full speed. The other day it was a little cold out and I turned the heat on. No heat. So I researched and found this issue to be the blend door. I replaced it with a brand new one. Still no heat. What should I check into next?
Old Nov 16, 2021 | 03:18 PM
SmackDaddy's Avatar
SmackDaddy
Is the blend door actuating?
Old Nov 16, 2021 | 04:13 PM
projectSHO89's Avatar
projectSHO89
For heat, you should ALWAYS first check to see if hot coolant is circulating through the heater core. If that ain't happening, nothing else matters (yet).
Old Nov 16, 2021 | 05:34 PM
ZacCobb's Avatar
ZacCobb
How would I be able to tell. I'm very much a novice in the field of mechanics.
cotntop288
Sep 15, 2020 07:46 PM
hotwater6
1997 - 2003 F150
Nov 2, 2013 01:48 AM
lgblack
1983 - 2012 Ranger & B-Series
Jul 29, 2011 06:53 PM
officer131
Aug 26, 2008 02:30 PM
