Default blowing AC/heat
Old Aug 25, 2008 | 11:24 PM
officer131's Avatar
officer131
I have been ahving a problem with the default AC and heating. I have heard it is the blend door, the soleniod, a vaccum leak, and on. I have not had the time to check for all of the problems individually. Before it was the AC. I never checked it for the heating. Today was cold enough for me to use the heat. So I checked it out and found that it was defaulting to the defrost vents.
Is there any different opinion on the problem or is it all the same options?
Old Aug 26, 2008 | 12:51 PM
Monsta's Avatar
Monsta
Sit. Stay.
When it defaults to defrost (hot or cold) then you have a vacuum issue. The blend door can be ruled out.
Old Aug 26, 2008 | 02:30 PM
X-70STANG-F150's Avatar
X-70STANG-F150
I had the same symptoms, but probably not the same cause. I actually had a vaccum hose disconnected on top of the AC condensor, under the hood. I don't know how it got disconnected, but it sure was an easy fix!!!
