Big Red
Old Nov 16, 2021 | 08:32 AM
Mrifle's Avatar
Mrifle
Big Red
My first rebuild at 57 years old. I have hooked a hose to vacuum advance. I'm havering a little problem with getting the idle down to where it doesn't jerk into gear. I have my timing at 22* BTDC. I can reduce the timing but then the truck doesn't excelerate and bogs.
My first rebuild.
Last edited by Mrifle; Nov 16, 2021 at 08:35 AM. Reason: Forgot engine and year 1975 2wd 390fe
Old Nov 16, 2021 | 08:56 AM
440 sixpack's Avatar
440 sixpack
Sounds like a vacuum leak or a carburation problem. at an idle try covering the carb with a rag and see if it speeds up or dies.
Id your vacuum advance hooked to ported or manifold ?
Old Nov 16, 2021 | 09:08 AM
Mrifle's Avatar
Mrifle
Vacuum hose
I have my hose attached left side of carburator.
I will try covering the carb to see if it changes anything.
I would say I'm a YouTube mechanic. 🙄
Old Nov 16, 2021 | 09:42 AM
Mark8man's Avatar
Mark8man
Need to put a vacuum gauge on it. If you don't have one they are inexpensive. Should not have to be at 22 BTDC. 10-14 is normal.
Still have point ignition? Is it a stock cam? Have you verified #1 piston is at TDC when pointer is at 0 degrees on balancer?
Old Nov 16, 2021 | 10:13 AM
Old Guy F-250's Avatar
Old Guy F-250
Are you 100% you have the timing marks lined up correct during assembly.
I am not a engine builder but I tend to agree with mark8man that 22 degrees??
seems like something not lining up correctly
Old Nov 16, 2021 | 10:51 PM
Mrifle's Avatar
Mrifle
Vacuum leak
Hello again.
I did the rag over the carburator and it died. I would assume I don't have a vacuum leak.
I'm bouncing back and forth from the electrical wiring nightmare to trying to get my timing to where it slows down the idle.
My project is a 1975 F250 with the 390fe.
jbcww
Nov 15, 2018 10:53 PM
Kyle Wood
Feb 14, 2018 06:40 AM
1979 300i6
Jan 26, 2015 04:07 PM
The_SnowMan710
34
Dec 29, 2010 04:01 PM
jeremyd72
Aug 30, 2007 10:20 AM
