Speedometer/Odometer Accuracy?
Old Nov 15, 2021 | 03:47 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Who, besides me, has checked their speedometer accuracy?
Checked mine over the weekend on a couple of different 100 mile stretches of interstate, and came up showing 98.3 miles on the odometer for 100 miles travelled.
So, short by 1.7%, and it seems about what the speedo is showing as well when in radar zones, 70 MPH on the speedo showing 71 on the radar.
Now, back when I had my 2012 F250, it's speedometer was off by 3%, but it was running over, 103 miles on the odometer for 100 miles travelled.
That meant that Ford was getting out of warranty 3000 miles early, but are on the opposite side with my current F250.
Old Nov 15, 2021 | 03:57 PM
kry226's Avatar
kry226
My 2019 was spot-on every time I checked by radar and GPS. Surprising, but that's what I found.
Old Nov 15, 2021 | 04:48 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
The other thing that happens when the actual miles are off is that it skews the fuel economy readouts and calculations.
So, mine have been off by about 1.7%, actually getting that much better fuel economy than I have been calculating.
Will have to add 1.7% to the miles to get closer to the correct MPG's.
Old Nov 15, 2021 | 06:00 PM
SARDiverDan's Avatar
SARDiverDan
I just fill it up when it hits 1/4 tank and not worry about it. Too many variables that can change the outcome of MPG.
Old Nov 15, 2021 | 06:22 PM
shawnee1's Avatar
shawnee1
I've experienced similar result with my 2019 with 20" A/T tires.
Old Nov 15, 2021 | 06:28 PM
sbrennan007's Avatar
sbrennan007
Same with my 2019 F350, speedo / odometer are perfectly spot on. I've actually checked it a couple times as normally they are off just a tad, but not with the Ford.
Old Nov 15, 2021 | 07:59 PM
Cee Jay's Avatar
Cee Jay
My F250 shows 1-1/2% faster on the speedo than it's actually going. I've never checked the odometer.
Old Nov 15, 2021 | 08:31 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
After using gps and odometer to verify my mpg was off 2% off, i went into the computer bias and adjusted it accordingly.
Its very easy to do and anybody can change it without consequences.
Old Nov 15, 2021 | 08:39 PM
RidgwaySD's Avatar
RidgwaySD
I am not sure how close mine was stock. When I put the bigger tires on I tuned the speedo to match gps using forscan.
Old Nov 16, 2021 | 10:54 AM
05F250DSL's Avatar
05F250DSL
have you changed tires at all? In forscan you can select the actual tire size you have. Mine was not correct when I got my ‘17.
Old Nov 16, 2021 | 11:52 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
No, original tires, only 15K miles so far.
Old Nov 16, 2021 | 12:12 PM
mcmurm's Avatar
mcmurm
Haven't checked odometer but speedometer is spot on. Had to adjust it in forscan for 37" tires though.
rvpuller
May 29, 2019 10:16 AM
GOVTMOD
Jun 13, 2012 08:57 AM
Gary Lewis
Feb 3, 2012 08:42 PM
92E150
Jan 19, 2008 07:10 AM
RobsRedFord
Apr 6, 2006 09:20 AM
