replacing agm battery with regular battery?
Old Apr 3, 2022 | 03:37 PM
Bluegrass 7's Avatar
Bluegrass 7
The difference between an AGM and Flooded Lead Acid is their build and resulting characteristics.
In Ford systems the AGM is not charged at the higher level of the Lead Acid type. That being 14.7 for AGM and well higher for L.A. types.
The state of charge is also different, aging is different and program handling vs core temperature is different.
If the program algorithm is not changed from AGM to Lead Acid and (battery size accounted for), the Lead Acid will be continuously >under charged resulting in possible issues with other functions and battery shortened life.
Replace the battery with the original build type and reset the Battery Management Module to zero out the last battery control data accumulated.
Bottom line is you cannot just throw anything in and meet the original system design and performance intent, even though is starts the vehicle, seems to work well, but will be affected later in its life span, giving you more issues than it should.
Good luck.
Old Apr 5, 2022 | 06:24 PM
maco's Avatar
maco
Just a quick other note : An AGM batteries terminals are backwards to a regular acid battery (@ least on my 2016) ..
To me It didn't look like you could put an older style battery in there ???
Old Apr 6, 2022 | 10:32 AM
GlueGuy's Avatar
GlueGuy
I'm not sure that's universally true. I know some manufacturers make two versions of many batteries with the terminals placed oppositely for each.
Old Apr 17, 2022 | 11:02 AM
tj fry's Avatar
tj fry
I had an almost new agm I installed, from a vehicle I sold. Terminals were reversed compared to original battery in truck. Was able to make them reach both posts.
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
coollooking96F350
Aug 16, 2011 08:11 AM
hojolabo
General Automotive Discussion
Oct 21, 2008 07:13 PM
ET1
Electrical Systems/Wiring
Nov 3, 2004 10:50 PM
76supercab2
Apr 20, 2004 11:50 AM
