ABS interior kit install tips?
Old Nov 14, 2021 | 01:07 PM
avf100's Avatar
avf100
I purchased the abs interior kit from Mid-Fifty, for those that have used this kit do you have any tips on the install?
I plan on taking them to an upholstery shop to have them covered. Should I test fit all the pieces first? My gut feeling is that I should.
I have the upper braces for the seat belts in the cab, will there be an issue there?
The truck is a 55
Old Nov 14, 2021 | 05:21 PM
Old F1's Avatar
Old F1
The head liner part in my "51 was a real pain, hard to fit and hard on the fingers.
I discovered later that the warmer the better and even molded the rear side parts with a heat gun for seat belt re-tractor covers, The abs becomes very flexible with heat.
Old Nov 14, 2021 | 07:13 PM
F100supercrew's Avatar
F100supercrew
Panels
Go to-- roddoors.com 530-828--9426
I Use his kits always look at videos easy headliner install in my 1954--55--56 Trucks
He will answer all your questions and great help
Make sure you install and pre-fit all items before you do any covering
Old Nov 16, 2021 | 07:11 AM
avf100's Avatar
avf100
Thank you, I watched the video and the headliner looks like it is fairly easy to do.
Since I have the seat belt brackets, the upper side pieces cant clip in to the roof. So I think I'll have to remove the clip off of the panel and maybe use velcro to hold it.
Cut this clip off
Eric1109
Jan 25, 2021 08:51 AM
mytbtruck
Dec 29, 2007 11:11 AM
Purple55
Apr 3, 2006 07:56 PM
imlowr2
32
Feb 3, 2006 06:34 PM
kdl98
Apr 22, 2002 06:31 AM
