Battery Voltage Drop
Old Nov 14, 2021 | 11:44 AM
don_sanders's Avatar
don_sanders
Fairly new battery (<8 months) in my truck.
Engine turns over but hasn’t fired.
Battery reads 12.4 volts when not under load. When I try to crank it voltage at the battery drops to 2-3 volts?
advice appreciated in advance.
a little more history…
Old starter locked up and so it was replaced. New battery cables and new starter cable. Solenoid is grounded, starter is grounded, block is grounded.
Old Nov 14, 2021 | 12:15 PM
lizardman1's Avatar
lizardman1
Load test the battery first, make sure it is up to snuff. If the battery is ok check the battery cables and most importantly the ground cable both ends.
Old Nov 14, 2021 | 01:31 PM
Crop Duster's Avatar
Crop Duster
If that is a reman starter you may have gotten a bad one. Or you have a bad battery. Put some jumpers on it and try it. The shop manual says .5 volt drop with the Ford starter.
Old Nov 14, 2021 | 04:17 PM
Koolkat's Avatar
Koolkat
Is there a chance that the battery has been frozen? Sounds silly I know but I don't know where you call home or the history of the battery.
Old Nov 14, 2021 | 07:56 PM
don_sanders
Live in Houston, so no freeze worries.
hooked up a load tester and it came back to replace battery so it would appear to be a bad battery
don_sanders
13
Jun 16, 2021 11:42 PM
danlee
Electrical Systems/Wiring
Jul 28, 2018 05:34 AM
Bobtailfan
Jun 21, 2012 01:48 AM
nothercrash
Jan 10, 2011 09:39 PM
sanpedro65
Jul 8, 2010 10:28 AM
