Starting problem
Old Jun 18, 2012 | 06:54 PM
Bobtailfan's Avatar
Bobtailfan
Starting problem
Hello,
I have a 1970 Bronco with a 68' 289 in it and I have not started it since 2008. Yea, I know...THAT is the problem!! Well, busy with work, kids, divorce...blah, blah, blah.
Anyway, When I attempted to start it, I got the dreaded "clicking". I have the battery on my jump start, and also tried jumping it from my F150, still only a click. My question, which is more likely to fail from just sitting, the starter or the relay. Unlike new vehicles, I could have probably dropped the starter in the time it took me to type this posting, but am looking for others opinions first.
Thanks for your help,
-John
Old Jun 18, 2012 | 07:03 PM
fmc400's Avatar
fmc400
MSEE
The answer is neither; it's the battery.
"Relay chatter" means the battery is too low. Initially, the battery is strong enough to let the solenoid make, and you hear the first click. But as soon as the starter is connected, the heavy load makes the battery fall over and it lets go of the solenoid. With the starter disconnected, the battery voltage goes back up and the solenoid makes again. This happens over and over, hence the rapid chatter.
Batteries can drain to the point that they place such a heavy load on the donor electrical system (jump starter, other vehicle, etc) that the target vehicle won't turn over with the dead battery in the path.
Old Jun 18, 2012 | 07:15 PM
Bobtailfan's Avatar
Bobtailfan
Well, that is good to hear because I planned on buying a battery anyway. I did not know the low battery could do this even when being jumped, or on a jump starter. Never stop learning.....
Thanks,
-John
Old Jun 18, 2012 | 08:14 PM
Franklin2's Avatar
Franklin2
You can take voltage readings while someone tries to start it. You cannot do any testing unless it's under load though.
For instance, if you put a meter on the battery, and hold the probes on there while someone else tries to start it, and the voltage drops very low, then yes it's the battery. If the voltage stays high on the battery, then you can look to a bad or corroded connection on one of the heavy wires down the line.
Just keep your negative probe on the neg of the battery, and move your positive probe down to the next connection if you get a good reading on the battery. Each time you move to a new point downstream, hold it on there and get someone to try and start it. When you lose the voltage when they try to crank it, then you know you are just beyond the bad connection/cable.
Old Jun 20, 2012 | 06:27 AM
Marky48170's Avatar
Marky48170
65 f250, 67 f100, 76 f250
Don't forget to check the mounting bracket of the solenoid. The bracket is the ground for the solenoid, I'd clean the bracket and mounting surface and put the battery on a charger and let it charge. Once charged and solenoid back on give it a try.
Old Jun 21, 2012 | 01:48 AM
joshofalltrades's Avatar
joshofalltrades
most jumper cables are way too small to start anything but a lawnmower with a dead battery in the way. they're great for charging the offending battery off the live vehicle, but thats about it unless you get huge cables.
in the same way, your jump box just won't be enough to overcome a fully dead battery.
if you still have a problem with a good battery and clean connections at the battery, then you can think about chasing down the problem as described in the above posts.
nothercrash
Jan 10, 2011 09:39 PM
cabloom300
Dec 17, 2009 04:05 PM
jmoats91
Aug 9, 2009 11:22 PM
9900imatt
Electrical Systems/Wiring
Nov 8, 2008 11:38 PM
RyanMiller
Oct 16, 2004 05:09 PM
