Dome light issue
Old Nov 14, 2021 | 09:29 AM
Jwalter04's Avatar
Jwalter04
Dome light issue
My dome light, cargo light, door chime only works with the passenger door, not the drivers. I replaced the switch on the drivers side, but it still isn’t working. The wiring to the switch appears ok. Any ideas where to troubleshoot next? 1994 F350 turbo idi. Standard cab
Old Dec 3, 2021 | 04:04 AM
Jwalter04's Avatar
Jwalter04
Anyone? Bueller? Hello?
Old Dec 3, 2021 | 09:59 AM
Mudsport96's Avatar
Mudsport96
I would say to get a cheap volt meter or even a test light and see if you have power at the switch. If there is no power there a new switch wont do you any good.
Old Dec 5, 2021 | 12:26 PM
Jwalter04's Avatar
Jwalter04
Tracing the wires back from the switch towards the dome light, I found a 4-wire connector in the cab corner just below the speaker. The smaller green/yellow wire had “rotted” off the plug. I ran a jumper around the plug to reconnect this wire. Problem solved.
Psyclopse
Jul 4, 2014 03:03 AM
pony
Jul 11, 2013 04:08 PM
lostin90s
Aug 3, 2007 07:34 PM
grnburg
Electrical Systems/Wiring
Feb 9, 2006 02:17 PM
Thumper47
1983 - 2012 Ranger & B-Series
Feb 19, 2004 03:24 PM
