IIRC Loctite 660 retaining compound would be used like on a shaft a bearing would fit on but the shaft was not the right size because of a bad bearing before spin on it and chewed it up?
It has been 30+ years since I went through a Loctite in house class at the hospital I worked at.
Will JBW stand up to the heat that may get to it if you plan to keep using as it was from the factory?
Did they ever make a cast iron one?
Dave ----
I checked the flatness with a straight edge,
It is not flat, so its more than filling minor pitting.
Waiting to hear back from a few sources on next action.
Dave ----
Tip I found out the other day; If you have exhaust leaks, say on a mating flange at a cat convertor or some other place down the line, JB weld works well to seal these off. Withstands the heat well and works much better than high temp silicone.
