Sea foam
Old Nov 11, 2021 | 01:51 PM
CarsonGarnett's Avatar
CarsonGarnett
Sea foam
Hey, I’m at work and picked up a few things for my truck prior to an oil change. I added sea foam to the crankcase before the oil change and after looking around a bit it seems like that wasn’t very smart. How bad have I screwed myself, and what should be done to remedy the situation?? Thanks guy. (I still have to drive it home)
Old Nov 11, 2021 | 02:53 PM
BuddyBarnes's Avatar
BuddyBarnes
You have not hurt anything. Just change the oil ( I would also change oil in HPOP reservoir) for this. Just don't do it again and you will be fine. I think some do this each oil change. You will be ok.
Old Nov 11, 2021 | 04:53 PM
97-psd's Avatar
97-psd
Agreed. You will need to change the oil again. Otherwise, you should be fine.
If you need to drive it home, take it easy.
Old Nov 11, 2021 | 08:52 PM
CarsonGarnett
Ok thanks guys will, definitely won’t do again, just changed the oil and all seems well. Lesson learned. I didn’t do the HPOP though. I know a little will be left in there, but 1-3 oz compared to almost 4 gallons of oil seems pretty trivial. Time will tell. Thanks for the help!
wfedwar
Aug 10, 2017 07:30 PM
Brian Fentress
Modular V10 (6.8l)
Apr 24, 2016 09:34 AM
MadWolf
Sep 9, 2015 12:28 PM
Quadzilla
6.7L Power Stroke Diesel
May 18, 2013 04:51 PM
gregorsway
Nov 1, 2010 04:43 PM
