What lifters do I have?
Old Nov 10, 2021 | 07:42 PM
Chase Sharp's Avatar
Chase Sharp
How can I tell if I have roller lifters or flat tappet lifters? I have a 1994 Ford F-150 351W. Thanks for the help!
Old Nov 10, 2021 | 07:57 PM
SFaulken's Avatar
SFaulken
Assuming its the original engine, a 1994 351W would be a roller cam motor.
Old Nov 10, 2021 | 08:36 PM
Conanski's Avatar
Conanski
To confirm your motor is a roller you would need to remove a valve cover(drivers side is easiest), unbolt a rocker and remove the pushrod. Then there are 2 thing that can be observed.. the length of the pushrod and the presence or absence of a dogbone around the lifter. The pushrods in a 5.8 roller ar 7.57" long whereas a falt tappet motor uses 8.2" pushrods. The dogbone fork is visible through the pushrod hole with a small flashlight.
Old Nov 11, 2021 | 08:34 AM
Chase Sharp
Ok thanks for the help, I’ll look for that!
hunnterr4
Apr 15, 2013 03:41 PM
Boba Fett
Dec 15, 2008 08:51 PM
64fordf100292
Jul 27, 2007 11:57 PM
Ryan356
Feb 11, 2004 06:27 AM
inderriedenc
Sep 3, 2001 10:40 PM
