Repair/replace fuel level sender? 7.3 IDI
Old Nov 10, 2021 | 04:33 PM
15W-40's Avatar
15W-40
When I got my truck, one fuel level sender worked OK. Now the other has gone out. From what I understand, they're both 19 gallon tanks.
Rear tank reads correctly for the first half of the tank. Under half, the needle bounces around aimlessly.
Front tank always reads empty.
I started looking for fuel level senders and it looks like they are no longer available for the diesels. Has anyone tried repairing one instead of replacing it? What typically fails on it? I'm going to have the bed off to fix my cab corner, so that would be a really nice time to tackle it.
Old Nov 10, 2021 | 08:00 PM
Wheeler.M1's Avatar
Wheeler.M1
Rock auto has fuel sender units. Check that first. Rear sender has been out of stock on there for a while. I know because I've been watching for one. Just add yourself into the wait list and get the front one. Also before you buy them, check your grounds and wiring. Either the unit goes out or the grounds just need to be redone.
Old Nov 10, 2021 | 08:09 PM
Charmalu's Avatar
Charmalu
I checked your profile info, looks like you have an 89 F250.
Here is the one for the rear tank.
https://puredieselpower.com/ford/6.9...ding-unit.html
I`ll poke around for the front sender
Here ya go, front and rear senders and the Shower Head.
https://www.gastankdepot.com/ford-tr...ing-units.html
Charlie
Old Nov 11, 2021 | 01:03 PM
15W-40's Avatar
15W-40
Charlie
Oh heck yeah. Thank you! From one Charlie to another.
Old Nov 12, 2021 | 04:17 AM
Nathan Fuentes's Avatar
Nathan Fuentes
where are the grounds located??
Old Yesterday | 12:49 PM
camelchop's Avatar
camelchop
Trailering
Midship Sending Unit
Hello to all in this thread (and beyond). I am needing a replacement sending unit for my 1991 7.3L IDI, 4x4, extended cab with E4OD. It is the front/side tank, which Ford calls M/S. Midship. I have the original owner's manual literature. There seems to be a discrepancy in capacities at various sites and with literature. Some places are referencing it as a 17 gallon, others 19 gallon, and owner's manual supplement, a 22 gallon tank. The old one has been tested. No less than 40 ohms, jumping up to beyond 200 ohms before what should be full.
I've found https://www.rockauto.com/en/catalog/...ding+unit,4436. But I'm looking to resolve the discrepancy in tank capacity before ordering.
I also made note of https://puredieselpower.com/filtered...Sending%20Unit & https://www.gastankdepot.com/fmsu7de...50-truckl.html seemingly available. Those are listed as 19 gallon.
At the end of the day, as long as I have the 'anatomically' correct one, I can bear with being a couple gallons off to the side of getting to the finish line. I'm just looking for insight/clarification from someone with experience.
Old Yesterday | 01:35 PM
Leroy Unlisted's Avatar
Leroy Unlisted
They're both 20 gallons, if you fill to when it goes as high up as possible into the fuel fill hose as you can, where you can see it, but without spilling.
I bet they're officially listed as 19, if you filled the entire space with no air in ideal scenarios, that's probably where they got 22, but, 20 ish, you could fill a little more, but then it might be sloshing out.
For ordering new senders, with dual tanks, go for the 19 gallon senders.
Old Today | 05:50 AM
Olds64's Avatar
Olds64
Don't order from Gas Tank Depot, he doesn't actually have a fuel sending unit to sell you. I recently tried to order the same fuel sending unit and had to deny charges on my credit card.
https://www.ford-trucks.com/forums/1...ank-depot.html
You can get the midship and rear fuel sender units from Amazon.
https://www.ford-trucks.com/forums/1...ding-unit.html
Old Today | 01:25 PM
BigBlue2's Avatar
BigBlue2
Can also check with MTS tank company. They mfgr plastic tanks but also sell various sending units that you can look up by year tank style.
CJWisinski
May 9, 2020 09:29 AM
fordtruck25089
Dec 8, 2014 05:57 PM
DADDYS73F250
Mar 9, 2011 12:57 PM
Reptar360
Nov 1, 2004 07:21 PM
