Rust hole in Frame and broken spring bracket.
Old Nov 10, 2021 | 01:02 PM
Chris Carpenter's Avatar
Chris Carpenter
Hello everyone. I recently purchased a 1987 F-250 and realized on major issue and I want to know if I can do the job or if I need to have someone else look at it. On the driver's side, right on the end of the frame, there is a large hole in the frame and the leaf spring bracket is being held in by the bed. I really like this truck and I think I can weld some 1/8" plate steel in where the hole is. I'm not sure how precise I need to be when drilling holes for the new bracket. I have photos of the hole and I hope someone wiser than me knows what to do. Many thanks
If i need to take a better photo please just let me know.
Old Nov 10, 2021 | 03:55 PM
wwhite's Avatar
wwhite
It's a parts truck. Frame is not safe for you, or anyone else on the road.
Where I live, if any frame work is done, the vehicle is automatically written off as salvage.
In my mind, that is not repairable.
Old Nov 10, 2021 | 06:00 PM
Hit Man X's Avatar
Hit Man X
Agreed. Parts truck or reframe if worth it...which I doubt. That amount of rot prob has destroyed the cab also.
Old Nov 10, 2021 | 07:51 PM
SFaulken's Avatar
SFaulken
No.
Period.
Old Nov 10, 2021 | 08:15 PM
sevensecondsuv's Avatar
sevensecondsuv
I'm not afraid to weld on a frame, but the problem is that it's almost a certainty that's not the only problem. Maybe no other holes, but I guarantee you it's getting dangerously thin elsewhere too. By the time you stripped it all down and patched/reinforced every thin area, you'd be money and time ahead just getting a different truck. Also I'm guessing the sheet metal looks just as bad? Usually the body goes first..
But look on the bright side - you now have an entire running parts truck worth of spare mechanical, electrical, and interior bits!
Old Nov 11, 2021 | 01:50 PM
GoinBoarding's Avatar
GoinBoarding
If you are going to attempt a repair, do use metal thicker than 1/8". The factory HD frame is 1/4" thick.
Old Nov 11, 2021 | 03:54 PM
thechief66's Avatar
thechief66
Holy crap, was that thing parked in the ocean??
Old Nov 11, 2021 | 11:45 PM
OhioFordFarm's Avatar
OhioFordFarm
Not only do you have sever frame issues, It looks as your missing a few leafs in your passenger side spring pack. Think You have more issues then you have noticed. Bummer. Always sucks when you buy a big bag of problems.
Old Nov 12, 2021 | 06:46 AM
GNR22's Avatar
GNR22
That was the second thing I noticed, broken leaf springs in the middle of the passenger side leaf pack.
The first thing I do when I go to look at old trucks is crawl under it and start looking at the frame, structural pieces, and driveline. If the frame is no good, the truck is useless.
Old Nov 12, 2021 | 07:56 PM
Negative Covfefe's Avatar
Negative Covfefe
Junk it. It sucks, I know, but it's really not worth the risk.
Old Nov 12, 2021 | 08:25 PM
Wheeler.M1's Avatar
Wheeler.M1
Well it's a good lesson to look under a vehicle from now on. There's no repairing that. Missing leaf springs also in rear left. What else is missing? Parts truck or donor.
Old Nov 13, 2021 | 11:12 AM
Negative Covfefe
Yeah, I don't mean to be a jerk, but this does seem like a lot of stuff to miss when buying a vehicle. I would've checked and seen this almost immediately.
Old Nov 13, 2021 | 05:11 PM
JJF20's Avatar
JJF20
Yeah, that is the shlts…
We were all 18 once, we all made mistakes. Hopefully you’re not in too deep, and you will learn from it, and worst case strip off any parts for your next truck. I’m going to assume you didn’t know any better, and someone took advantage of that. Hopefully they didn’t send you down the road in it…
Unfortunately, without seeing the rest of the truck, I’m going to assume it’s all pretty bad, metal and Mtce wise.
Any chance you know the seller? Or have any recourse on it? Maybe get your parents involved at this point. I don’t know what the deal was, but you might be able to get back out of it and return the truck (with a tow truck, don’t drive that thing). That’s a very slight maybe, but you never know depending on the circumstances of who and what the deal was, or what you were told.
Good luck with it,
Mayerstom
Oct 3, 2020 12:04 PM
jmkelly
16
May 21, 2009 05:02 PM
lowtrkn2k
Oct 20, 2008 05:51 PM
Ranger Louie
Paint & Bodywork
Jul 17, 2005 11:57 AM
1982fordf100
Nov 17, 2004 12:33 AM
