High speed vibration
Old Nov 13, 2021 | 06:37 AM
truckdog62563's Avatar
truckdog62563
Marmon-Herrington Man
Add my welcome. Nice truck and hope you sort out your vibration. Has anybody else noticed that the truck still has its hyper rare spare tire brace? One of only a couple I’ve seen that are originals. One of the 53-56 guys copied mine a few years ago for his flatbed. Stu
Old Nov 15, 2021 | 11:37 AM
flatsoface's Avatar
flatsoface
I took a look and all mounts are brand new and intact - thanks!
Old Nov 15, 2021 | 11:38 AM
flatsoface's Avatar
flatsoface
The u-joints were all in phase so not this issue - thank you for the heads-up! Learn something new everyday!
Old Nov 15, 2021 | 11:40 AM
flatsoface's Avatar
flatsoface
Not sure how to check this without pulling the tranny? The H motor was introduced in1947, no? I wonder how to check numbers to see if it is the matching numbers motor?
Old Nov 16, 2021 | 08:14 PM
38 coupe's Avatar
38 coupe
If you rev the engine up to 2000 rpm when sitting still does it vibrate?
Old Nov 16, 2021 | 08:49 PM
sammywayne23's Avatar
sammywayne23
Exactly what 38’ coupe said! See what it does sitting still. Then you can narrow it down to engine or driveline or even wheels. I know how much fun it can be to track something down…keep us posted!
Old Nov 17, 2021 | 09:37 AM
flatsoface's Avatar
flatsoface
It does not vibrate around 2000 rpm when sitting still.
Old Nov 17, 2021 | 09:50 AM
52 Merc's Avatar
52 Merc
Yes, but a bad coil or wires can rev fine at idle but go all to pieces under load. Still not definitive. I'm still not sure if we've determined electrical or mechanical?
Old Nov 17, 2021 | 10:01 AM
flatsoface's Avatar
flatsoface
no vibration at stand still
Here is 53 seconds at idle and revving up at stand still. Pretty smooth here...
Last edited by flatsoface; Nov 17, 2021 at 10:11 AM. Reason: adding Youtube link - movie file would not upload
Old Nov 17, 2021 | 07:35 PM
38 coupe's Avatar
38 coupe
That does look like it runs nice and smooth. Mechanical engine balance appears fine then (crank, pistons, flywheel, clutch, etc.). That leaves an engine misfire at speed or a transmission issue that becomes apparent at speed.
Have you coasted down an hill at high speed and verified no balance issue with the engine at idle?
Old Nov 18, 2021 | 01:52 PM
flatsoface's Avatar
flatsoface
The 47 flatbed has all new Tornell 10 ply 7.50 X 17 tires and it has been in storage awhile. Maybe these bias ply tires are flat-spotted and that is making the awful vibration??
Old Nov 18, 2021 | 05:11 PM
sammywayne23
I would think after 100 miles they would have worn in though. I can tell you from my experience with my F3, that’s on 7.50 x 17 tires, and has the stock 4.86 rear end and 4 speed…that at over 50MPH the thing is wound up pretty good, throw in a bad road and it may feel kinda rough, but I’ve learned it’s the nature of these old trucks. So I usually keep the truck at 45 50 and that’s the sweet spot, at least for me.
Old Nov 19, 2021 | 01:58 PM
  #28
flatsoface's Avatar
flatsoface
The truck was in storage for two years and the tires were only holding 28-32 lbs. psi. The max rating is 90 psi. I'll fill to max and drive it.
Old Nov 19, 2021 | 01:59 PM
  #29
flatsoface's Avatar
flatsoface
I'll coast down hill at high speed next.
How do I verify no balance at idle? Sorry - I am new to these flatheads...
Old Nov 19, 2021 | 09:13 PM
  #30
38 coupe's Avatar
38 coupe
I should have been more clear, while coasting down a hill put the transmission in neutral and let the engine idle. If the vibration is gone it is engine or transmission input shaft related. If the vibration is still there it is transmission output shaft, u-joint, drive shaft, rear axle, or wheel balance. We can keep helping you narrow down what is the cause.
