A new reprogramed module is going to run me $300, so I may just run 12volts to the module's brown wire on a switch.... with a in-line fuse. I don't have up-fitter switches. Anyone recommend a fuse to run off of?
The trailer is only a 7x16 enclosed and all led, I would only be lighting the running lights. I could run a tap fuse from something in the passenger kick panel?
2017 F350 Plat 6.2
What about forscan? been a while since I've opened it and looked at what modules it can see,, but you might be able to fix this yourself correctly and not do a okie fix...
My boat trailer has LED lights all around and I don't have any issues with the lights and the truck not recognizing the trailer.
Same here. I have 4 trailers with factory LED lighting. No problems. Plus a boat trailer that I installed new Harbor Freight LED lights on. It doesn't seem to be a problem for the truck.
I have been meaning to purchase the adaptor for forscan and try and learn about it. I'm not to great with computer stuff, I just wanted to adjust tire psi
If anyone is playing around with forscan, can you check to see if there is a trailer control module that can be changed? maybe trailer running lights are not turn on? wow wouldn't that be nice!
Originally Posted by Norcalpr
Also, dumb question but you said you checked fuse 99, did you check the fuses for the trailer module? Should be a couple under the hood .
Yes I check all the fuses that are labelled "trailer" in the owners manual , the mini's and those square ones... all good.
was going to purchase this adaptor....not going to bother now, its not my issue.
