Unknown issue
Old Nov 6, 2021 | 05:32 PM
Scorpolis's Avatar
Scorpolis
Exclamation Unknown issue
Hey all I've got an 89 Ford F-150 with the EFI 351W, and I cant seem to get the thing to run properly. I've replaced the fuel pumps (all 3) the fuel filter, the map sensor, the IAC valve, it has new spark plugs and wires, New distributor, ICM, cap, and rotor, new coil. I can get it to run for about 10-20 minutes then nothing. i don't hear any indication that the timing chain is sloppy.
Fuel pressure to start is around 38 psi, then when its running it drops down to 30/32 psi.
I'm out of ideas on where to go next.
Old Nov 6, 2021 | 09:12 PM
My4Fordtrucks's Avatar
My4Fordtrucks
What fault codes did you get from the KOEO self test? List the active and stored codes separately. Unfortunately, throwing new parts at the problem has probably complicated diagnosing the problem. .
Old Nov 6, 2021 | 09:13 PM
Scorpolis's Avatar
Scorpolis
I will run the test tomorrow and list them here
Kkrob89
Dec 31, 2020 09:06 AM
Bear999
13
Oct 3, 2015 09:23 AM
geraldo14
19
May 25, 2008 08:15 PM
Canadianice
Bronco II
22
May 7, 2007 06:22 PM
fordman102
Jul 27, 2003 04:54 PM
