3rd post
Old May 21, 2008 | 04:11 PM
geraldo14's Avatar
geraldo14
3rd post
I've posted questions on this forum a few times but I'm still having a difficult time with this truck. It's a 94 F250 with a 5.8 with 94K miles. I've replaced the inline fuel filter, TPS, cap, rotor, plugs, wires and even the coil, I've also applied fuel injection cleaner. The truck sat for quite a while and I've put a new tank of gas in but it still cuts out at idle and under acceleration. I've been all over the Internet looking and reading and I've even contacted a tech at our local Ford dealership. They suggested checking the fuel pressure and maybe even the ignition. Questions are, do you check the fuel pressure from the stem on top of the fuel rail that looks like a tire stem? secondly, when they say check the ignition, is that the timing? Thanks again in advance.
Jerry
Old May 21, 2008 | 04:29 PM
Virto's Avatar
Virto
That's called a Schrader Valve...and yes, that's where you check.
Lets us know what the numbers are.
Old May 21, 2008 | 04:36 PM
geraldo14's Avatar
geraldo14
Thanks
Thanks for answering. I forgot to mention that it starts fine during a cold start, after it idles down is when it starts missing.
Jerry
Old May 22, 2008 | 03:52 AM
LCAM-01XA's Avatar
LCAM-01XA
Timing don't usually slip, but you can check it, it should be at 10*BTDC with the SPOUT connector unplugged. I'm thinking they mean either just basic stuff like plugs and wires and coil (all of which you already got replaced), or the TFI module on the side of the dizzy, at 94k miles you ain't quite yet at the point where you should be expecting a TFI module failure, but it's a known problem and can cause all sorts of weirdness.
Fuel pressure like Virto said is checked at the shrader valve, for a MPFI system (like you have) you should be seeing 35-40psi at idle.
Old May 22, 2008 | 08:31 AM
geraldo14's Avatar
geraldo14
thanks
Thanks for the suggestions and help, I appreciate it, this truck is driving me nuts!!! I'll give all of your suggestions a shot and I'll let you know what I find.
Jerry
Old May 23, 2008 | 02:11 PM
geraldo14's Avatar
geraldo14
fuel test and numbers
OK, I bought an INNOVA fuel injection pressure test kit. I hooked up the hose to the schrader valve, turned the key on and the fuel pump primed and the gauge peaked at 40 PSI and then gradually dropped out to 0. Next, I turned the engine on and it ran at 32 PSI steady, I then pushed the throttle down and only then would the pressure climb to 39 or 40 PSI, after I released the pedal it would drop back down to 32 PSI. After I ran the test I pushed the release valve on the test gauge and no fuel drained out. Any ideas or suggestions would be greatly appreciated.
Jerry
Old May 23, 2008 | 02:54 PM
Conanski's Avatar
Conanski
Your test indicates the FPR is operating normally, though the pressure should not drop when the fuel pump stops or the engine is shut off, this may indicate a leaking injector.
You next step should be to pull the codes.. if you haven't done so already. Ford Fuel Injection
Also clean the IAC valve on the side of the throttlebody, and find a dark place where you can view the motor running with no ambient light(inside a garage at night with the lights off. If you see a light show from the plug wires they should be replaced.
Old May 23, 2008 | 03:06 PM
alxsnmr's Avatar
alxsnmr
You may also want to check plug wire routing. It is another known issue of the trucks for the plug wires to crossfire and cause a miss. The suggestion of checking your timing on a warm idle engine will help make sure the engine is firing at the right spot.
Old May 23, 2008 | 03:25 PM
LCAM-01XA's Avatar
LCAM-01XA
Jerry, your fuel pressure looks good, the pump seems to be working fine and the pressure regulator doing its job. I agree with Conanski tho, it shouldn't go down to zero, it drops down a bit but not that much down...
Old May 23, 2008 | 05:44 PM
G/T's Avatar
G/T
i have the 88 f-250 4x4 460 c6.when i would drive it felt like i was running out of fuel but pick back up an go again,taking off from a stop it would sputter an take off,then it got this attitude ill start when i want,anyway come to find out it was the stator inside the dist.went to the bone yard pulled one out its ran every since.you may want to hollow out your cat.convert. depending on your smog laws where you live,where i live there are no laws but your own.
Old May 23, 2008 | 06:40 PM
netscaner's Avatar
netscaner
A stuck open EGR will give you a bad idlle.
Old May 24, 2008 | 12:26 AM
geraldo14's Avatar
geraldo14
Thanks
Thanks again all of you guys for you help and suggestions. I ran an OBD1 code reader from INNOVA and found no trouble codes. I did replace the plug wires, plugs, cap and rotor etc. I haven't checked the timing yet, I think that's the only thing I haven't checked. It's really bugging the hell out of me that this truck is so full of trouble and trouble shooting. It could very well be the stator in the distributor, I'll also check the EGR valve etc. as you guys have suggested.
Jerry
Old May 24, 2008 | 01:06 AM
LCAM-01XA's Avatar
LCAM-01XA
Jerry, just so you know, the TFI distributors are pretty expensive, so be prepared for a low-triple-digit sticker shock. Dunno if the parts are sold separately. Your problem however does sound very much like how my Lincoln was acting up when the TFI module was going bad, my engine is a 5.0 SEFI and its EEC-IV system is damn near identical to what your 5.8 runs off. To pull the TFI module off the distributor you'll need a special tool that costs about $5 and is usually in stock at Advance Auto Parts, same store can usually test the module for you as well, and sell you a new one if it comes down to it. The module I put in my car was a GP Sorensen unit for $30-something, and it's been working just fine. A note of caution here - never buy an electronics piece made by a company named Wells (found at AutoZone usually), their sensors are okay but the TFI and HEI modules have caused many a truck to get stranded on the side of the road.
Old May 24, 2008 | 02:05 AM
geraldo14's Avatar
geraldo14
Tfi
Thanks M.L.S.C. what does the TFI look like? I've looked over the distributor and I can't see any external parts. What does TFI stand for? thanks again.
Jerry
Old May 24, 2008 | 02:23 AM
LCAM-01XA's Avatar
LCAM-01XA
TFI stands for Thick Film Ignition, or something like that. The TFI module is the plastic doohickey that sits on the side of the distributor and has a 6-wire harness plug into it. Read here on how it works:
http://www.autozone.com/servlet/UiBr...3d801abd3a.jsp
Read this article for some ideas, remember a 5.8 (351) is just a long-stroke 5.0 (302):
FordMuscle Webmagazine - Tales of the big & ugly Work Truck. 1989 F-150 5.0L Project Truck
