2015 high idle question
Old Nov 6, 2021 | 09:35 AM
Lbenge's Avatar
Lbenge
I’ve got a 2015 6.7 that been tuned with GDP tuning, running an EZ Lynk tuner.
ive found a ‘BD Diesel Ford High Idle Kit’ that’s supposed to work with my truck.
from their website: ‘This high idle kit allows the user to control the engine RPM while stationary by interfacing with the SEIC (stationary engine idle control) wiring found in all Ford Power Stroke diesel trucks (8500gvw and up)’
my question is, my GDP Tuning does not have a high idle function currently, and from my understanding, they no longer provide tunes. Would it be possible to run this high idle switch with my tuning? Or will it not work? Thanks!
here’s a link to the high idle switch I’m referencing:
https://www.thoroughbreddiesel.com/1036610/
Old Nov 6, 2021 | 10:52 AM
blackfords's Avatar
blackfords
Why not try this for 12 bucks and a upfitter switch
Old Nov 6, 2021 | 05:31 PM
Lbenge's Avatar
Lbenge
Originally Posted by blackfords
how would you propose doing this?
Old Nov 6, 2021 | 05:46 PM
blackfords's Avatar
blackfords
Fte forum. Did this to my 13, 16, and 19
Old Nov 6, 2021 | 05:48 PM
blackfords's Avatar
blackfords
Old Nov 6, 2021 | 06:52 PM
Lbenge's Avatar
Lbenge
are there instructions anywhere on how to do this though? I’m not quite understanding just looking at the pictures
Old Nov 7, 2021 | 07:33 AM
blackfords's Avatar
blackfords
You need to find the wire bundle. It is on the driver's side behind the kick panel. Then pull the 4 wires out that match the color in the 2nd pic. The yellow/with tracer goes to the up fit switch and the other three go to the potenmeter. Just follow the configuration on the pic, then your good to mount. Set the emergency brake and turn on the up fit switch. Then you can adjust it to your desired rpm. Most have them set to about 1200 rpm. You can set the e-brake just till the light goes on turn on the switch. When you start or remote start it will kick up to what is set. Release the brake or turn off the switch to disable the function. Let me know if you have any other questions.
Old Nov 7, 2021 | 07:42 AM
blackfords's Avatar
blackfords
Also the first pic has a resistor wired in. It will be a set rpm with no adjustment. Get the adjustable one like in the 2nd picture. Send some pics for others to veiw. It shouldn't take very long to do.
Old Nov 7, 2021 | 10:01 AM
Lbenge's Avatar
Lbenge
awesome, thanks a lot for your time and advice! My only remaining question is whether or not it will interfere with my EZ Lynk tuner..it doesn’t sound like it should but just making sure. Thanks again!
Old Nov 7, 2021 | 10:10 AM
blackfords's Avatar
blackfords
No it will not.
Old Nov 7, 2021 | 06:15 PM
Dirthawg2.0's Avatar
Dirthawg2.0
Link to the huge thread on this subject. > https://www.ford-trucks.com/forums/1...ictures-4.html
And a link to the Ford Bulletin regarding SEIC > https://madocumentupload.marketingas...b525f&v5=False
Old Nov 7, 2021 | 08:24 PM
4df150's Avatar
4df150
I tapped the 12 volt positive from the 12 volt accessory plug instead of the upfitter switch.
Rob89
Jan 22, 2025 08:19 AM
eryoung
Dec 18, 2017 03:05 PM
jonrjen
6.7L Power Stroke Diesel
71
Sep 2, 2015 02:27 AM
crack
Nov 30, 2006 08:41 AM
02expeditionEB
Jan 25, 2005 05:18 PM
