What connector is this?
Nov 4, 2021 | 05:51 PM
driver side frame rail, right behind front bumper
Nov 4, 2021 | 05:54 PM
I believe factory fog lights are powered through that connector.
Nov 4, 2021 | 06:06 PM
Correct. Along with some other features. But that is what I used it for, to add fogs to my STX.
Nov 4, 2021 | 07:51 PM
Quote:
Originally Posted by
h20camper
ok, sounds good, but what adapter did you use to connect to a 16 pin port?
where can I find the pin mapping for it? and which options it enables?
Nov 4, 2021 | 08:07 PM
I bought the OEM harness that connects to it and then to the fog lights. I used an aftermarket harness that converted the OEM to standard aftermarket
Pin Out here:
3 = 12v
6 = Ground Headlamp Panel Left
10 = Left Fog
11 = Right Fog
12 = CanBus High Speed 2 (Upper) Low
13 = CanBus High Speed 2 (Upper) High
14 - Ground Headlamp Panel Right
Nov 4, 2021 | 08:24 PM
h20camper
Pin Out here:
3 = 12v
10 = Left Fog
11 = Right Fog
hopefully, the pin position is same on a '22... I'm having hell finding the correct OEM part number ...
anyway, thanks for the info
Nov 5, 2021 | 11:24 AM
SeniorRVer
The connector is a molex mx150. You can either buy the pins separately or the whole connector easily...
Use a set of doubpe crimp pliers obviously...
Nov 8, 2021 | 11:17 PM
So once you connect them up, how do you turn them on from the inside?
Nov 10, 2021 | 06:05 AM
RubenZ
by swapping out the headlamp control with one that has a fog light button
TomHay
Apr 10, 2023 01:47 AM
Steve56
Jan 5, 2021 06:36 AM
Rockhead115
Mar 3, 2020 11:16 AM
MikeMcCasland
May 14, 2009 01:12 AM
Bernie Lomax
Apr 28, 2008 10:30 PM
