Sponsored by: Real Truck
7.3 Deisel engine
Old Nov 3, 2021 | 04:37 PM
F100supercrew's Avatar
F100supercrew
7.3 Deisel engine
Just got a 2001 Ford F-450 stake body with a 7.3 diesel -- what must be done to add to fuel now getting cold---must it be plugged in at night--NEW to a 7.3 Diesel but truck was a 1 owner and great condition and had to settle for the engine--
So what should I be doing to engine for maintenance over Gas engine-- Thanks
Old Nov 3, 2021 | 04:53 PM
BCMO's Avatar
BCMO
https://www.ford-trucks.com/forums/forum31/
explore the tech folders at the top sticky area, more info then you ever wanted to know thats a good thing
Old Nov 4, 2021 | 08:21 AM
AACoPD05's Avatar
AACoPD05
I dont add anything to mine, I just plug it in over night when it get super cold over. As far as maintenance, change the oil and fuel filter, should be good to go.
Old Nov 4, 2021 | 12:36 PM
redford's Avatar
redford
FTE Leadership Emeritus
Here in NE Wisconsin, I just make sure that any fuel purchased from November to April is winterized. Use a DIESEL FUEL anti-gel additive if you suspect the fuel quality.
Plugging in your block heater helps, but anything more than 4 hours is wasting electricity. If you need to leave at 8AM have the heater set up on a timer to start at 4AM.
Browse the 7.3L PSD engine forum for other helpful tips.
Derbin
7.3L / 6.8L V8 Gasoline Engines
38
Nov 23, 2021 06:12 PM
Sous
59
Feb 8, 2019 08:33 PM
phoskins
Feb 28, 2018 11:35 AM
longhorns13
General Diesel Discussion
13
Sep 29, 2009 10:00 PM
Fuelhog 5212
Jun 13, 2009 11:05 AM
