No Crank
Old Nov 2, 2021 | 02:30 PM
PatriotUSA1964's Avatar
PatriotUSA1964
No Crank
Hey Folks, sorry but it’s a no start and
some of you have been helping me with troubleshooting my 05 f350.
I just replaced the crankshaft position sensor. Went to start the truck and now it will not run at all. This is the message my OBDII gives
Heading: Emissions Related Engine DTCs
Message: No powertrain DCTs or freeze frame data is currently stored in the vehicles computer.
What the heck is going on? Getting desperate any and all help is needed. Thank you
Old Nov 2, 2021 | 02:53 PM
bismic's Avatar
bismic
Start by checking fuse 22 under the dash on the drivers side.
Then you can try cranking with the key off and jumpering the starter solenoid wire (passenger side by the vacuum pump) to the passenger side battery (+) terminal.
It is the yellow with light blue striped colored wire which is adjacent to the passenger side battery in the engine compartment, it is near the vacuum pump. It has a "squeeze-and-pull" type connection.
https://cimg8.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/960x720/80-image_2e79e5ce15d4581001f68628a6aeb55b1619332d.jpg
https://cimg0.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/960x720/80-image_a1bd34109315547fcef1b8679959fa26c7cadcb7.jpg
Old Nov 2, 2021 | 03:15 PM
PatriotUSA1964
Fuse is good. It will turn over just fine but it will not run. It sound like it is going to run for about 1/2 second and stops.
Old Nov 2, 2021 | 03:18 PM
bismic's Avatar
bismic
Oh, your title said "No Crank", which means to most of us that you have no engine rotation with the key on.
Next step is to see if you have BOTH FICM sync and CAM/CRANK sync, and then if the FICM is issuing an Injector Pulse Width command (all available PIDS to be seen on a scan tool).
Lastly, post the cranking rpms.
Old Nov 3, 2021 | 01:28 PM
BryanStein's Avatar
BryanStein
Is the RPM gauge working and showing about the correct RPM? It takes 150 rpm to fire the injectors. If so, the crank position sensor is likely correct. IF the gauge is not working, you've either got a blown fuse or your not getting a signal from the crank sensor.
Old Nov 3, 2021 | 03:00 PM
PatriotUSA1964
Thank you, I’m going to get a fuse tester before I go back to the crank position sensor. I am not getting but about 2 rpm,s
Old Nov 3, 2021 | 05:20 PM
BryanStein's Avatar
BryanStein
I had an issue with a cam position sensor once. I had to find out which pin it was that fed into the PCM and checked the Ohms there. I discovered I had no resistance, which told me it was a bad connection or a bad wire. Luckily the plug was simply loose. It fired right up after I cleaned the connector and plugged it back in.
Old Nov 3, 2021 | 06:07 PM
PatriotUSA1964
Hi Brian,
If it’s not a fuse which I haven’t checked yet I will look into the cam position sensor . I’m not a mechanic and I’m learning this diesel. Took it to a shop and the guy looking at it said he couldn’t get a code. I brought it home, plugged in my OBDII and I did. It coded for the crank position sensor. I don’t know why he couldn’t get one, he had a high end reader. Won’t be going back there. I replaced the crank position sensor and it wouldn’t run afterwards. I’m hoping I didn’t mess up a wire at the pigtail. I wish I knew what to look for. I guess we all have to learn. I appreciate you!
Old Nov 3, 2021 | 06:15 PM
bismic's Avatar
bismic
I gave you methods to test the crank sensor and harness in your other thread.
"To troubleshoot the ckp sensor: Check the resistance between the connector on the PCM Pin 30 (harness side) and Pin 41 (harness side). Resistance should be 300-400 ohms. The CKP reading you should be getting from the CKP sensor, is between 150 to 200Hz, directly proportional to engine cranking RPM when the engine is cranked over."
Replacing things without testing is a recipe to spend unneeded money, but unfortunately so many seem to follow that process.
Seems like we had to twist your arm to get a scan tool other than the SCT, but it seems that it is proving its value ....
Buying cheap non-OEM parts is unwise also, if that is possibly what you did on the CKP.
Old Nov 3, 2021 | 06:36 PM
PatriotUSA1964
no I don’t buy cheap parts. The CKP was an $80 part. I did see them for as little as $30 but I’m not going there. All I have to do now is learn the abbreviations for the troubleshooting.🥴
I already had the scan tool but I needed the truck back on the road ASAP, I’m too slow.
Old Nov 3, 2021 | 06:53 PM
bismic's Avatar
bismic
Interesting.
Full retail on the OEM crankshaft sensor (CKP) is $50 at a dealership. You shouldn't have to pay more than that (and it can be had for $37 from dealerships that do internet business). Clearly you didn't get it at a dealership, so, even though it was expensive, it could be aftermarket.
https://www.tascaparts.com/oem-parts/ford-crankshaft-position-sensor-3c3z6c315aa
https://www.ficmrepair.com/index.cfm/page/ptype=product/product_id=61/mode=prod/prd61.htm
PCM - PowerTrain Control Module
Old Nov 3, 2021 | 07:35 PM
PatriotUSA1964
Interesting.
Yes but I needed to get it, and was hoping it would get me back on the road. But…
Old Nov 3, 2021 | 08:18 PM
xcrsp440's Avatar
xcrsp440
Non motorcraft electrical parts will be hit or miss if they are within factory specs. And if they are , can often fail sooner than expected.
Do your self a favor, gets parts from a Ford dealer in person or online. eBay and Amazon motorcraft is a crap shoot often being counterfeit in a good looking package.
Old Nov 3, 2021 | 08:28 PM
PatriotUSA1964
Good advice, will do.
Old Nov 3, 2021 | 09:48 PM
bismic's Avatar
bismic
We've all been there. That said, the main point you are missing is (from the above links) that ANY dealership near you would sell you the proper part for $50, and it would almost certainly be in stock for immediate purchase. Someone may be ripping you off if you actually spent $80, but it is certainly your call on how to spend money. Another, maybe remote, possibility is that it might not be the correct part that was purchased.
Well anyway - best of luck.
