1988 ford code 18
Old Nov 9, 2021 | 05:08 PM
ironman1952's Avatar
ironman1952
Thanks again Sandymane,
I'll check it out. I have a rebuilt distributor and if I get time tomorrow I'm going to give it a try.
Jack
Old Nov 10, 2021 | 06:17 AM
rla2005's Avatar
rla2005
Be aware those rebuilt distributors are not what they may appear to be. It may have fresh paint and little else. Many times the "rebuilder" never tests the PIP sensor so you may have a dud out of the box or a short fuse before you are left stranded.
Old Nov 10, 2021 | 03:29 PM
ironman1952
You are correct rla2005, I put the rebuilt distributor in today and it runs worse. I think I will put a motor craft pickup in my old distributor. Today I located the computer pin 20,40 and 60 pin grounds and cleaned all but the 20 pin ground. It is grounded to the driver side inner fender with the screw run in before the fender was put on. I think I can get to it though. I cleaned several other body grounds also. If the pickup doesn't do it I'm going to check computer for bad capacitors. I found out today on the road if you push the go pedal to the floor it quits skipping and takes of real strong. The oxygen sensor was bad and replaced but the plug is in bad shape. I have a new pigtail to put on next. maybe that will help.
Thanks
Jack
Huckle berry
1983 - 2012 Ranger & B-Series
Feb 28, 2017 09:35 AM
rhoward
Jun 24, 2014 07:17 PM
N4CQD
Jul 19, 2012 02:06 PM
stylintoys
1997 - 2003 F150
Sep 28, 2006 03:02 PM
optikal illushun
Oct 8, 2003 06:59 AM
