Bed Camera Delete
Old Nov 1, 2021 | 07:30 AM
blackdog2086's Avatar
blackdog2086
Bed Camera Delete
I've got a 22 350 Lariat with the full camera package. I just ordered a cap (which I won't get until Feb. if I'm lucky) and will need to remove my bed camera due to clearance issues as the camera protrudes a bit. I hate to lose the camera but I really need the cap for my intended purposes. I've found blocking plates to cover the third brake light hole but was wondering if removing the camera will cause an error code or somehow mess up the rest of the camera's?
Old Nov 1, 2021 | 08:06 AM
99powerstrokedF250's Avatar
99powerstrokedF250
You shouldn't lose the rest of the cameras. However, if it's a good cap maker they should be able to clearance the cap to allow the camera to remain. I presume you're getting a fiberglass cap, which should be VERY easy to alter since they just have to adjust the form.
Old Nov 1, 2021 | 09:12 AM
DK4's Avatar
DK4
I'd try and figure out a way to mount the camera inside the cap topper. Cover plate for the light with a hole and a grommet and extend the wiring inside the cap.
Old Nov 1, 2021 | 11:42 AM
Joe T's Avatar
Joe T
Probably can unplug it now just to see before ordering the cap?
Old Nov 1, 2021 | 04:22 PM
llblake64's Avatar
llblake64
Sounds like you're getting an A.R.E. by the long delay in delivery. Just got a new Leer cap installed today (ordered October 11th, at shop October 30th) and it has an indent in the front of the cap for the factory mounted light and camera. No clearance issues.
Old Nov 1, 2021 | 04:42 PM
(Overthebars)'s Avatar
(Overthebars)
Interested in selling the brake light with the camera or trading for one without the camera? I would be interested. Just need to see if it can be added after the fact I'm assuming there's a harness for it already there.
Old Nov 1, 2021 | 05:01 PM
JHForman812's Avatar
JHForman812
You can turn that camera off in Forscan I believe. But if you remove it without removing it in forscan you will generate an error.
Old Nov 1, 2021 | 05:32 PM
blackdog2086
I am thinking about that, but need to figure a way without drilling a hole in a brand new cap.
Old Nov 1, 2021 | 05:36 PM
blackdog2086
That's helpful info. I've got the forescan dongle but haven't done anything with it yet. Once the snow hits I'll have time to play with it a bit as I definitely want to enable some features and disable a few others.
Old Nov 1, 2021 | 05:41 PM
blackdog2086
Yeah, it's an A.R.E. CX. I wonder why the difference in delivery time between the ARE's and the Leer's? I'll check with the installer on possibly leaving it there, but in reality it's useless at that point anyway unless you want to look at the front of your cap.
Old Nov 1, 2021 | 07:05 PM
llblake64's Avatar
llblake64
My 2017 also had the 360 cameras and I found that the only time I used that camera was when loading the truck camper. We traded the truck camper for a travel trailer earlier this year so I don't think I'd have any use for that camera anyway since it's not used in the 360 view.
The difference in delivery was one of the main reasons I went with the Leer. That and also the Leer was a couple hundred less than a comparably equipped ARE, even though you have to pay for installation with the Leer. My options from both were a little limited since I have the long bed.
Truck2Board
2004 - 2008 F150
May 11, 2008 06:32 PM
Chorizo520
Apr 3, 2007 09:39 PM
yellowboy
2004 - 2008 F150
Mar 26, 2007 05:07 PM
HaroldCallahan
1983 - 2012 Ranger & B-Series
Mar 2, 2006 09:18 PM
phantom22
Appearance & Dress-Up
Mar 22, 2004 01:06 AM
