MSD vs OEM
Old Nov 1, 2021 | 12:20 AM
rclc's Avatar
rclc
Trailering
MSD vs OEM
Normal circumstances, will replacing my Duraspark II ignition system with a MSD ignition system improve the efficiency of my 1992 vintage 5.8l.
Old Nov 1, 2021 | 12:35 AM
Conanski's Avatar
Conanski
Your '92 doesn't have a Duraspark ignition if it's all original, but even of it does the short answer is no the MSD alone won't make any difference to efficiency.... assuming the current system is working correctly.
Old Nov 1, 2021 | 08:52 AM
anangryford's Avatar
anangryford
MSD TFI distributors are garbage. Do NOT replace an OEM with one. I will fail in short order if it ever even works. They are not manufactured to tight enough tolerances for the ford ecm to like them in most cases.
Old Nov 1, 2021 | 09:03 AM
rclc's Avatar
rclc
Trailering
MSD Vs OEM
Thanks for the reply. I'm chasing a intermittent miss. and thinking a hotter spark will fix the issue. Just thinking but realize just find the prob. is the real test. I wish it was as easy as changing a tire. Again I know enough to be stupid. Poss PIP issue. Fuel pressure is very good. ,1500 rpm right when I'm in 4th and steady load notice the most interruptions. Eng temp normal. BY PASS EGR, MINIMAL INTERRUPTION. There this dreaded discussion. Bigger hammer but enjoy this ride to much.
Old Nov 1, 2021 | 09:10 AM
rclc's Avatar
rclc
Trailering
92 Flareside, 5.8l 4x4 E40D. 167k, std cab. Jasper eng.
Old Nov 1, 2021 | 09:26 AM
anangryford
I was chasing a miss that ended up being due to an MSD distributor. To rule out the coil (MSD coil), I pulled the motorcraft one out of another 5.0 vehicle I have. It made it worse. I suspect the MSD coil is hotter so if you want a hotter spark you could try an MSD coil. I would replace the cap, rotor, wires and plugs if you haven't yet. Then possibly the module on the distributor if that doesn't solve your problem. I would recommend only using motorcraft parts if possible.
Old Nov 1, 2021 | 09:35 AM
Hit Man X's Avatar
Hit Man X
I had a 6AL on my 88 F150 for years and maybe 25k. Box kicked it, it would only run the truck upon cold starts...like a failing TFI. Removed it, no issues since and no power differences I could tell. I did keep their hotter coil.
Even Duraspark II is solid, just use a Motorcraft box if it does fail and drive on down the road.
Last edited by Hit Man X; Nov 1, 2021 at 02:18 PM. Reason: Added year since I have many F150s...
Old Nov 1, 2021 | 01:41 PM
wwhite's Avatar
wwhite
Stick to the basics, and only replace with OEM FoMoCo/Motorcraft parts.
Plugs, cap/rotor, coil, maybe even new spark plug wires. Make sure they are routed correctly to prevent cross-fire.
Old Nov 1, 2021 | 02:01 PM
kenny nunez's Avatar
kenny nunez
Thumbs down M S D
My Spark Disappeared
Old Nov 1, 2021 | 02:42 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
May Suddenly Die.
Old Nov 1, 2021 | 02:51 PM
SFaulken's Avatar
SFaulken
Funny. Aside from being ground sensitive, I've had *zero* issues with any MSD product I've put on anything. And the grounding issues were usually because I was in a hurry and got lazy. That being said, I highly doubt that you're going to see any benefit from going to an aftermarket ignition system on an engine that is otherwise stock. The Ford TFI Ignition is fairly robust, and works pretty well, as long as you use quality parts.
Old Nov 6, 2021 | 08:49 PM
rclc's Avatar
rclc
Trailering
PIP issue
After warm up, engine has a miss and am wondering if the magnetic pickup can cause this and yet not cause a ECL. 92 Flareside, 5.8l
cjbronco
Oct 13, 2005 09:40 AM
fordracing_1979
Feb 12, 2005 11:08 PM
WhëëlMå1
1978 - 1996 Big Bronco
Feb 4, 2003 10:10 PM
95fordbronco302
Apr 2, 2002 04:17 PM
Bill Martin
Jul 24, 2000 07:53 AM
