Alternator ID
Old Oct 31, 2021 | 07:50 PM
56exp's Avatar
56exp
Alternator ID
A question for the more electronically inclined. I have an alternator from a 1985 E350 #x60A E1TFAA L18B. I am assuming x60A means it is a 60amp? I think it is a 1G and I need an external regulator. Am I on the right track??I did not take it apart from the truck it came off and I am finding different wiring schematics. It is a 460- c6 from a 85 E350 RV . Thank you Dean
Old Nov 1, 2021 | 01:40 PM
5851a's Avatar
5851a
IG have the main power wire attached with a nut on the back. 2G has built in regulator on back and 2 plug in wires on side/top for main power. 2G should be avoided since high amps could melt power wire plug due poor design at connection. The 60A does sound right.
Old Nov 1, 2021 | 04:01 PM
56exp's Avatar
56exp
Thanks 5851a, the back has studs marked STA , BAT, FLD, GRD. All on the back nothing on the side. I had it tested a few years ago but didn't know to ask what it was. As I get closer to wiring I need to figure it out. Thanks Dean
Old Nov 1, 2021 | 06:28 PM
5851a's Avatar
5851a
Old Nov 4, 2021 | 09:01 AM
56exp's Avatar
56exp
That looks just like it ,thanks Dean
Michael Manglos
Feb 24, 2014 12:22 AM
sciondude09
Mar 15, 2009 05:59 AM
sconut1
Feb 4, 2009 08:17 PM
