alternator question
Old Feb 22, 2014 | 04:52 PM
Michael Manglos's Avatar
Michael Manglos
alternator question
I have a 1990 f-250 with the standard charging system and I am considering a 165 amp alternator meant for either the ambulance package or school bus. How will this affect my truck?
Old Feb 22, 2014 | 06:40 PM
genscripter's Avatar
genscripter
probably not. if I remember correctly, the older ambulances (like my van) are generators with external regulators. I think the 1990 F250 is an alternator. Can someone else chime in?
I shouldn't say probably not, because you probably just need to get the whole wiring harness.
But whatever, if you are going to do all that, then just do a 3G alternator.... then you don't have to screw with rehabbing the ambulance alternator.
Old Feb 22, 2014 | 09:06 PM
hairyboxnoogle's Avatar
hairyboxnoogle
The guy who rebuilt mine said that the ambulance alternators are completely different.
Old Feb 22, 2014 | 09:18 PM
Chevy_Eater's Avatar
Chevy_Eater
You have a generator?! I thought generators died out in the 60s!
Old Feb 23, 2014 | 06:35 AM
Michael Manglos
I have located a 165 amp unit that apears tobe in a case identical to mine, i assume the voltage regulator would need to be changed. What im more concerned about is will the added amps harm the standard harness?
Old Feb 23, 2014 | 07:10 AM
Don Senkow's Avatar
Don Senkow
You should likely use at least a #2 cable from the alternator output to the battery. That is a bit oversized, but better than too small. A continuous load will build heat over time. Wire Size Charts show #2 rated at 181 amps.
Old Feb 23, 2014 | 10:51 PM
joshofalltrades's Avatar
joshofalltrades
if it were mine, i would just install a 130a 3g alternator from a mid-90s ford taurus. or be a real bad-azz like me and install 2 of them. theres only about 200 write-ups around here about doing the upgrade, and we all recommend upgrading the charge wire to reduce the risk of overheating it. 2ga straight to the battery is all you need.
Old Feb 24, 2014 | 12:22 AM
finitetime's Avatar
finitetime
The standard replacement that Autozone sells for my 93 is 135 amps anyways. Why do you need that much power. These trucks really don't use that much.
1973supercamper
Mar 24, 2016 07:28 AM
nilzlofgren
Nov 15, 2015 05:24 PM
BigTomMiller
Aerostar
Sep 26, 2003 07:37 AM
z 97ford1
1997 - 2003 F150
Aug 24, 2003 07:53 AM
