361 block use for stroker
Old Oct 30, 2021 | 10:05 PM
idhiboy's Avatar
idhiboy
I can get a hold of a FE 361 block, apparently pulled from a 1970 truck. There are no other engine parts, just the bare cylinder block.
1- Can this be used for a stroker build?
2- if so are there issues with having cylinder head and intake fitment? (plan on edelbrock performer heads and intake)
3- is the distributor bushing a big issue or could machine shop/engine shop make that part?
4- any other fitment issues (motor mounts, flywheel, transmission connection etc)
Have read through quite a few threads but can't tell what is true vs speculation...
Thanks!
Old Oct 30, 2021 | 11:12 PM
85e150's Avatar
85e150
No issues. Distributor bushing might be available if you search for one. Just make sure you have usable bores.
Old Oct 31, 2021 | 09:35 AM
idhiboy's Avatar
idhiboy
Thank you....I don't know slot about cylinder inspection so will probably just ask my machine shop to inspect
Old Nov 3, 2021 | 08:44 PM
85e150's Avatar
85e150
Easy to check the bore, just use an inside caliper at several points in the bore. If it's been bored already, consider a sonic check to make sure you can clean it up without ending up too thin cylinder walls.
Old Nov 4, 2021 | 04:32 AM
idhiboy's Avatar
idhiboy
I will measure that with my calipers...don't know much about the history of block so will have shop sonic check and/or magnaflux it anyways
thanks!
393STROKER
Apr 21, 2009 12:43 PM
WALFORD'S 56
Nov 28, 2007 09:03 PM
obey_your_master
Sep 22, 2007 04:21 PM
Fordman7780
Oct 10, 2002 10:57 PM
fordmann
Jan 6, 2002 12:22 PM
