Replace Instrument Cluster
Old Nov 3, 2003 | 04:29 PM
blue92f150's Avatar
blue92f150
Question Replace Instrument Cluster
I have a 92 F150 with the 4.9 and 5 speed manual. It has the "standard" instrument cluster without the tach. Of course I'd like to convert to the cluster with a tach. I found this on Ebay and wanted opinions on whether it would work.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2440658692
The Ebay ad says it is a 94 automatic V8. Will any of that matter for my 92 manual I6?
Thanks. Jim B.
Old Nov 3, 2003 | 05:18 PM
aikigod's Avatar
aikigod
You shouldn't (99% sure) have a problem swapping out the instrument cluster. I believe that all gauges for 92-96 are interchangeable, and Ford has all the wiring already in place. It's basically just plug-and-play; take the gauges you need off the new one and install them onto yours.
Old Nov 3, 2003 | 05:38 PM
brown 4x4's Avatar
brown 4x4
There was a change in wiring for the voltmeter somewhere around 1994. You may have to study the wiring for both clusters and harnesses and do some minor rewiring.
You'll probably want to take the center speedometer out of your old cluster and put it in the new one. This way you'll keep your original mileage reading.
As for being from an automatic, you can replace the PRND21 plate with the black one from your old cluster.
Old Nov 3, 2003 | 08:35 PM
blue92f150's Avatar
blue92f150
Rewire?
I really don't want to have to do any "rewiring". I'd just rather buy the correct cluster and plug-and-play. On that note, any suggestions on where to get a 92 cluster (with tach) at a resonable price? Thanks. Jim B.
Old Nov 3, 2003 | 10:15 PM
brannma's Avatar
brannma
www.car-part.com should steer you in the right direction for the cluster. its best to get a cluster the same year as your truck (Example: Where the 1992 has a Fuel Reset Light on the far left of the idiot light row, in the 1994 that is an Airbag light instead, and the wiring is on the opposite side of the cluster from where a 1992's would be. Also, the tach came in 2 different vareieties, one for the 6 cyl and 1 for 8 cyl, so they are different. Find a cluster at a yard, and use your existing odometer in the new cluster. Should cost about $100.
Old Nov 3, 2003 | 10:25 PM
steve83's Avatar
steve83
Just FYI:
You can't transfer the gauge panels (except the speedo) between non-tach and tach clusters.
http://www.superford.org/registry/ve...045&original=1
Old Nov 4, 2003 | 12:12 AM
brown 4x4's Avatar
brown 4x4
The tach is the same for 6 and 8 cylinder engines. There is just an extra wire grounded for one (don't remember for sure which). So a factory tach will automatically be accurate.
88gtblack
Aug 31, 2012 04:09 PM
FLJ
Electrical Systems/Wiring
May 30, 2009 04:01 AM
Nightrain
19
Aug 3, 2006 12:04 PM
dhag911
20
Aug 3, 2005 01:04 AM
