It came out of a 1996 Bronco, but will it work in my 1994 F-150? I know that they switched computer systems in 1996, but I was still curious if this would work...
I'll be in the lookout for them in the bone-yards, just to see what I can come up with. I had a SunPro tach to the right of the instrument cluster until I reached to turn my radio down one night and missed... Now there's a big 'ol hole where the tach once stood.
I've gotta get another cover, so that's something that's going to go along with the OEM tach install.
Plug and play...other than spending a few minutes swapping your speedometer into the new cluster. Expect it to take less than an hour. Also I'd recommend buying a whole set of bulbs and replacing all of them on the new cluster, so you don't have to take the darned thing out again.
Nightrain,
I'm going over to a salvage yard that I'm pretty sure has one or two clusters and face plates. I'm wanting to do the same thing to my 94 250. I'll check on price for you if you're interested. I'm over in Jackson so getting them to you shouldn't be too hard.
I don't know if you've heard of Highway 54 Auto Salvage in Alamo, but I sent an e-mail over to them, requesting an instrument cluster with a tach for my truck. I'm pretty doggone sure that they'll have it. I'll let you know how it turns out!
Keep an eye out for me in your area. I'll keep mine peeled here, also!
BTW, I'm less than 30 miles from you in Lexington.
I'll try to get to the place today or tomorrow at the latest. I talked to him the other day and could have got a cluster for 40 bucks. Didn't have the cash with me and the wife had the checkbook. Then had to bond a friend out and that put the brakes on that project for a little bit. I'll see if he'll let me wander through his yard and see what I can spot for clusters and faceplates.
I put a 95 cluster in my 96. It worked. The ABS light came on. I pulled the ABS bulb and everything else works fine. I have no ABS at this point.
As stated above 92-93 interchange, 94-95 interchange, 96 is stand alone.
Yeah, 94-95 with tach, and preferably the black face plate. The PO on mine decided to gorilla-torque the mounting screws sometime in the past and split the plastic behind the snap-in trim piece.
