1978 - 1996 Big Bronco
Camber Question
Old Oct 30, 2021 | 03:46 PM
curtisfords1963's Avatar
curtisfords1963
Camber Question
Hello,
I have a 4 inch lift on a 95 Bronco and would like to gain more positive camber by lowering the beams into the 6 inch mounting points on the pivot brackets has anyone tried this.
Thanks
Old Oct 30, 2021 | 06:14 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m fairly certain that lowering the pivot point would increase negative camber.
How far out of spec is your truck?
Old Oct 30, 2021 | 08:24 PM
curtisfords1963
Sorry i meant more negative camber tires are wearing on outside edge.
Not sure of what the specs are but here's a snapshot of the alignment results.
Old Dec 20, 2021 | 04:12 PM
manicmechanic007's Avatar
manicmechanic007
Yes the left side needs more camber
You can live with the right side at .2
Means you would need to raise the pivot on the left side
I assume you have the max 1.5 degree camber shim installed
ccbrett
Jan 28, 2011 09:01 AM
redlight mike
Offroad & 4x4
Oct 19, 2007 06:30 PM
casanovaceo
Offroad & 4x4
Aug 25, 2004 02:40 PM
JeremyH
Offroad & 4x4
Jun 9, 2004 08:25 AM
