1994 E-150 van fuel pump replacement help?
Old Nov 5, 2021 | 09:30 AM
  #31
Jackslap77's Avatar
Jackslap77
Originally Posted by subford
Sorry my error.
The wire from pin#2 goes through the PCM and then to Neg post of the battery.
It did not dawn on me that power from other places going to ground through pin #40 & #60 would change the ohm reading to ground.
As long as you get near zero ohms with the key off doing the test pin #2 to NEG post the PCM should have a good ground.
OK no worries thanks. Is there still more testing to be done or do i pull the PCM now?
It looks very buried and inaccessible. Do I have to remove the fender to access from the bottom instead? I've seen that mentioned somewhere I think.
Old Nov 5, 2021 | 09:45 AM
  #32
subford's Avatar
subford
It looks like time to pull it out with a 10mm socket.
No it comes out under the hood in the center of the dash.
Attachment 279129
Old Nov 5, 2021 | 12:41 PM
  #33
Jackslap77's Avatar
Jackslap77
Got it thanks.
Results of suggested test:
1. There is ground using continuity test on multimeter at pins 20, 40,60. Key was in off position, black lead was on battery neg post and red lead was inserted into the PCM connector at the corresponding chart locations.
2. Then set multimeter to voltage instead of continuity, turned key to on position. Connected black lead on multimeter to neg battery post, red lead inserted into chart positions for 37 and 57. There is 11.8 volts at pins 37 and at 57. Key in on position
3. Did the same thing for Pin #2. It shows less than 1 volt. Key in on position
Are these tests done correctly?
Old Nov 5, 2021 | 01:19 PM
  #34
subford's Avatar
subford
The tests sound all right.
Time to pull out the PCM.
Then open it up and see what it looks like.
Old Nov 5, 2021 | 02:04 PM
  #35
Jackslap77's Avatar
Jackslap77
Shouldn't pin #2 have 12 volts with key in on position? Anyway heres the board. TBH it doesn't show massive signs of damage to my eyes but what do I know? Last photo is lame because I zoomed in on phone. Just wanted to show that capacitor. Slightly oiled/black side to it, but the solder and legs on the bottom look ok
Old Nov 5, 2021 | 03:14 PM
  #36
SFaulken's Avatar
SFaulken
Originally Posted by Jackslap77
Shouldn't pin #2 have 12 volts with key in on position? Anyway heres the board. TBH it doesn't show massive signs of damage to my eyes but what do I know? Last photo is lame because I zoomed in on phone. Just wanted to show that capacitor. Slightly oiled/black side to it, but the solder and legs on the bottom look ok.
Those 2 blue caps are toast, and they've been leaking. And there's obviously been water inside the case, and on the board. Time for a replacement, recapping, or sending it out to have somebody rework it.
Old Nov 5, 2021 | 04:20 PM
  #37
subford's Avatar
subford
Only when the brake pedal is pushed down.
Old Nov 5, 2021 | 04:50 PM
  #38
Jackslap77's Avatar
Jackslap77
lol ignore that I accidentally "reported" you for this post lmaooooooo., I clicked the alert button thinking it was PM hahaha I'm an idiot.
Old Nov 5, 2021 | 04:59 PM
  #39
Jackslap77's Avatar
Jackslap77
Yo will this part work? I mean, its autozone so at least i can return it. Ebay parts might be a bit more sketchy IDK?
My PCM part number is F4TF-12A650-NA
This part from autozone states fits F4TF and california emissions, which......I'm in California so yay....
This says ECM though
https://www.autozone.com/engine-mana...c334/56237_0_0
Old Nov 5, 2021 | 05:05 PM
  #40
SFaulken's Avatar
SFaulken
I am absolutely the wrong guy to ask about whether it will work, especially when you throw california emissions into the mix. But there are plenty of guys here that know a heck of alot more about which ECM will work in which application, than I do.
Oh, and ECM, PCM, ECU, CPU, and about a half dozen different acronyms are all describing the same thing.
Old Nov 5, 2021 | 07:26 PM
  #41
subford's Avatar
subford
Yes it looks like it is the right one as long as you order the one with the numbers below:
Part # ECC334
SKU # 56237
Old Nov 5, 2021 | 07:38 PM
  #42
subford's Avatar
subford
I do not see ECM in the link you posted.
Did you mean OEM?
Not sure if it was ever really called ECM by FORD but the name EEC was changed to PCM in 1993.
It had been called EEC from at least 1983 to 1992.
Attachment 279128
Old Nov 10, 2021 | 08:37 AM
  #43
Jackslap77's Avatar
Jackslap77
OK it took 4 days to arrive but I got the new ECM from autozone link. Shipped from somewhere in San Diego.
I plugged it in and turned the key and the fuel pump spun right up. So I fully installed it into its slot, put the fuel pump back down into the tank and in 10 seconds of cranking or so, the van started up.
I drove it a little bit. Seems to run smoother if Im honest lol, but maybe placebo effect. I'm pretty familiar with every little sputter and shake of this old thing. So I guess thanks to everyone for all the help on this issue.
One last issue though, maybe deserves its own thread but nah.
Why do my windshield wipers come on and do 4-5 swipes every single time I turn the key? Its been doing it for years. At first it was only during the cold months that it would do it, but recently its even doing it during the summer time. Where do I start for troubleshooting this issue?
RazorsEDGE
16
Jun 22, 2021 01:46 PM
voodoolord
30
Jul 27, 2015 12:11 PM
Texas Mad Man
May 22, 2014 12:55 PM
Badgoat
Jan 26, 2007 02:51 PM
powercell24
Dec 12, 2002 12:56 PM
