Sponsored by: Real Truck
Transmission compatibility
Old Oct 27, 2021 | 05:24 PM
Dereksouthern's Avatar
Dereksouthern
I have a super duty f250 1999 without speed sensors will a newer 4r100 with speed sensors work if not can it be modified to work?
Old Oct 27, 2021 | 07:23 PM
Bently_Coop's Avatar
Bently_Coop
What Engine do you have?
A V10 transmission should work, bell housing is the same with 5.4 but 5.4 internals aren't strong enough.
Diesel has a different housing.
Old Oct 27, 2021 | 10:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The newer trans can be modified to work. You DO need to match the engine. As pointed out above, the diesel has a unique bellhousing. The 5.4L trans has weaker internals and the V10 will tear it up.
The solenoid body is different and needs to be changed. Also, there is an orifice in the pump body that needs to be changed. The later trans has a 0.250" hole, and the earlier trans has a 0.030 orifice. You need to change from the hole to the orifice or the torque converter clutch lockup will SLAM on.
Old Oct 28, 2021 | 12:08 AM
Dereksouthern
Thank you, so i can use the newer 4r100 if I change the solenoid body with the old one and changed the orifice size I'll be good? What about the torque converter the older torque converter has one clutch and the new torque converter has three I do believe so should I change torque converters also
Old Oct 28, 2021 | 04:23 PM
Mark Kovalsky
You would be better off with the older converter.
theoldwizard
Mar 24, 2021 09:21 AM
fender1325
Aug 7, 2020 01:16 PM
Louisville Joe
Dec 11, 2018 04:01 PM
hindy
Aug 13, 2017 08:26 PM
