Opinions on Limited Slips 10.5" Axle
Hey all, I'm getting close to rebuilding my rear axle. It's at 325k (leaking). There is a lot more options than I thought there was so I'd like some help narrowing things down. I'm looking for opinions on the true trac vs the Auburn Cone LS - the new one is called a grip n lock. Secondly what rebuild kit did you go with ( gears, bearings, seals, etc). BTW it's a work truck with winter duty still and some mild trailering. Thanks.
The following users liked this post:
You made a good choice. One thing to note you can change the behavior of the truetrac buy changing the gear oil type. If you run the petroleum-mineral based oil for the truetrac it locks both tires quick and firm when you are having fun applying the go pedal. For my driving preference I run Valvoline full synthetic and it provides a good balance on tire slip before it engages.
Respectfully I am going to disagree in regards to the Sterling. The sterling axle runs at much higher temperatures than most light truck axles by utilizing a full synthetic in my sterling it did reduce the max operating temp by 20 degrees versus running conventional.
An open diff sucks for street use in the rain, snow, loose gravel or even on dry pavement trying to take off quick, and it's what he has already. Having it locked isn't great on the street either, you will get far more use out of a Truetrac.
No thanks, I dealt with that garbage long enough. A Truetrac in the rear is superior to an open diff in those situations.
