New shocks
Old Oct 26, 2021 | 06:08 PM
Jblc87's Avatar
Jblc87
New shocks
Hello everybody got a question on shocks for my 05 6.0 X. I currently have what I believe is about an 8 inch lift on it all spring. Rode good for the 4 years I’ve had it until the last 6 months or so. My shocks are shot. I have duals up front and I believe all the shocks are zone shocks. My question is will the bilstien 5125 dual shocks for f250 with a 4-6 inch lift fit on the front? My measurements are 31.5 inches in front and 32 in back. If those will work then I gotta find some for the back. I know the back is X specific Thanks a lot
Old Oct 26, 2021 | 08:03 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Hub center to bottom of fender arch stock ride height is
23 front
24 rear
if you want to know your shock dimensions, remove a front and rear.
measure the extended and collapsed length.
Starting on page 19 of this catalog has is custom fit lengths
https://www.bilstein.com/us/wp-conte...og-2019WEB.pdf
Old Oct 26, 2021 | 08:21 PM
Jblc87's Avatar
Jblc87
Ok I’ll take them off and measure. I know as they sit on the X I measured 23 inches from eye to eye front and back. I know the X sits 2 inches lower than the superduty in stock form so I’m hopeful these will fit. Thanks
Old Oct 27, 2021 | 12:06 AM
pirate4x4_camo
unless you know the extended length or compressed length your measurement is meaningless
Old Oct 27, 2021 | 11:23 AM
Jblc87's Avatar
Jblc87
Ok just got done measuring and it’s about 20inches collapsed and 33 extended both front and back
Old Oct 27, 2021 | 01:41 PM
Jblc87's Avatar
Jblc87
I think these are the wrong size shocks for this setup. Doesn’t seem right to me. Just sitting normal on the truck they look like they are almost bottomed out. They never have (at least I don’t think they have). I called bilstein and they told me that they don’t make anything for this setup. Honestly I think these measurements threw them off. I don’t think I need 33-34” of extension, but I do think I need a lower compressed measurement
Old Oct 28, 2021 | 11:01 PM
pirate4x4_camo
You are correct, that is not a correct setup for your ride height.
lets start at the beginning.
what is your center of hub to bottom of fender arch measurement?
this will tell your ride height and from that i will calculate the shock length you need.
Old Oct 29, 2021 | 12:06 AM
Jblc87's Avatar
Jblc87
Center hub to bottom of fender is 31.5” in front and 32” in back
Old Oct 29, 2021 | 09:46 AM
pirate4x4_camo
stock is 23-24
you are 32 giving you an 8" lift.
Normally a 12" stroke shock is used on a 8" lift but given yours is a 13" ( very oddball as industry stadard is increments of about 2" )
I heasitate to recomend a 12" in front based off how your current shocks setup looks.
normally you want the shock shaft to be 1/2 way inside the shock leaving 1/2 of the shaft outside the shock when the vehicle is sitting at ride height.
your shock tower height looks to be the same as stock but may not be, this could be contribution the problem. normally on a modified suspension the goal is to extent the shock tower to make room for the longer shocks.
anyhow, I would probally try a 10" shock up front and the rear should still be a 12". ( unless they have monkeyed with that as well).
Old Oct 31, 2021 | 07:25 AM
Jblc87's Avatar
Jblc87
Ok thank you for the info. So I’m looking at the link you posted above for the bilstein shocks. Do you recommend a different valving for the front and back considering duals in the front? Thanks again
Old Oct 31, 2021 | 08:17 AM
Jblc87's Avatar
Jblc87
Would you recommend duals up front with the 170/60 valving and then the 255/70 for the rear?
Old Oct 31, 2021 | 05:10 PM
pirate4x4_camo
I would not “recommend” dual 2” in the first place.
i prefer to run a single 2.5”
but i digress…
yes, if you are going to continue to run duals than 170/60 for the front.
For the rears, what size tires are you running or plan to run ,
if 40”s that i would probably go 360/80
if 35’s than the 255/70 are probably the ticket.
37’s Kinda on the fence but since your front duals are going to be stiff i would probably go 360/80 as well. They are cheap enough you can always swap them if that is not to your liking.
edit, On second thought, not being a fan of more than a 4” increase in ride height on the Ex since after a dozen or so different setups ( just never like the handling) i would go with the 360/80 if you are running 37’s
Old Nov 1, 2021 | 11:53 AM
Jblc87's Avatar
Jblc87
Ok thanks for the info. I am currently running 37’s but it has crossed my mind to lower the X down to about 4” or so. But that will probably have to wait a while and it tows my travel trailer fairly well for what it is. As far as the duals up front that were on it when I bought it, I wouldn’t mind swapping back to a single up front but I can’t find the bracket to mount a single shock anywhere. So it’s looking like I will have to stick with duals for a while. Thanks again for all the info this site is real helpful. Btw here’s my X. I’ve been snooping around this forum for a good couple years now but never posted till now.
Old Nov 1, 2021 | 12:27 PM
pirate4x4_camo
you don't need to change brackets to run a single shock, if your setup holds 2 shocks and you remove 1 shock you now have a single shock.
Old Nov 3, 2021 | 05:18 AM
Jblc87's Avatar
Jblc87
That’s a great idea pirate! Saves me some $. Now do you think it matters if the single shock is mounted on the rear mount or the front mount? And if I go single up front now should I go with the same valving as the back? Thanks
