D44 upper ball joint
Old Oct 24, 2021 | 10:37 AM
moneypit ford's Avatar
moneypit ford
Hello, I'm new to forum posting and looking for tips/tricks to greasing the upper ball joint on my 1979 F250 front D44. There is a threaded plug in the bottom of the ball joint.
Old Oct 24, 2021 | 11:08 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
That is a grease zerk and you need to get a grease gun and service it. The grease gun should come with a very common size grease zerk fitting.You can use the same gun to service the drive shaft u joints and tie rod ends. Push and hold the end on and make sure to pull it straight off and try not to crank is over sideways to get the tip to release.
Old Oct 24, 2021 | 09:29 PM
tbear853's Avatar
tbear853
Some greasable joints have just a small plug instead of a zerk, I use a adapter on those and remove the plug to inject grease with a pointy looking adapter, then put the plug back. Might need to rotate the axle to get room to do it easier.
Old Oct 27, 2021 | 03:41 PM
77&79F250's Avatar
77&79F250
And some ball joints are considered "none serviceable". Aka sealed ball joints. But it you have a threaded plug in the bottom of the ball joint then yes you need to get a grease gun with a needle tip for greasing.
Old Oct 27, 2021 | 05:05 PM
wyrm73's Avatar
wyrm73
I think I know what the OP is referencing. IIRC, On small hub D44's at least, the grease zerk is too long and will interfere with the axle shaft u-joints. You grease them and then remove the zerk fitting and install the plug until the next time they need to be greased.
Old Oct 27, 2021 | 08:37 PM
moneypit ford
Yes, I was attempting to grease the upper ball joint. I removed the small threaded plug from the ball joint and tried to insert a zerk. Failed miserably. I will source a grease needle and try again. Thanks for all the replies.
justellis98
Aug 30, 2024 11:48 AM
Deadsquiggles
Jun 6, 2021 01:27 PM
Wesley Keyser
Apr 23, 2021 09:59 AM
Wicked Endings
Aug 22, 2010 06:23 AM
mxfam4x4
Oct 27, 2006 06:40 PM
