Long warm ups
Old Oct 26, 2021 | 01:00 PM
Woodie49's Avatar
Woodie49
Trailering
Long warm ups
Can a ported vacuum switch cause long warm ups on a 1976 ford f-150 with 300
Old Oct 27, 2021 | 12:19 PM
Ozzie H.'s Avatar
Ozzie H.
While I'm not sure, somehow I doubt it. Check the thermostat; it may be stuck open. How long is "long"? And what part of the world do you live?
Old Oct 27, 2021 | 04:07 PM
5851a's Avatar
5851a
Do you have the stock air cleaner with the pre heat tube and manifold tins in place and operating.
Old Oct 27, 2021 | 08:37 PM
Woodie49's Avatar
Woodie49
Trailering
Yes
Old Oct 27, 2021 | 08:40 PM
Woodie49's Avatar
Woodie49
Trailering
About 5 min, I live in California
Old Oct 27, 2021 | 09:08 PM
ranger140892's Avatar
ranger140892
Grumpy goat
Was it running ok until recently? Has your weather gotten cooler recently? Does the engine hesitate on acceleration, until the engine is at normal operating temperature? If so, that's just classic cold weather lean condition. Cold air is denser than hot air, so it's making your air/fuel mixture more lean. You probably know this, but carburetors cannot adjust the air fuel ratio like EFI does. Unlike EFI, your carburetor can't account for the engine, or more specifically the intake air temp, being at below normal operating temperature. So, the engine has to be warmed up longer before it runs correctly. If it persists once engine is at normal operating temp, then there's a problem. Your carburetor could need to be richened up, or you could have a vacuum leak.
Rusty_Old_F250
Dec 22, 2013 08:32 PM
OzarksFord
Feb 12, 2007 06:46 PM
ford390gashog
Nov 22, 2004 01:58 AM
gslk1214
General Automotive Discussion
Apr 18, 2004 08:14 PM
