Decking the 400
Old Oct 23, 2021 | 02:10 PM
BlueWhiteFord's Avatar
BlueWhiteFord
Decking the 400
How unorthodox is it to deck the block to achieve a good piston to deck distance? Also how much can safely be taken off a 400 block? Are there any drawbacks to decking more? I am aware of the need to also machine the intake manifold.
just trying to look at all available options.
Thanks in Advance
Old Oct 24, 2021 | 07:22 AM
DaveMcLain's Avatar
DaveMcLain
You could deck the block as much as you want really. The only drawbacks are like you say possible manifold fit problems as well as changing the preload in the valvetrain. From what I've seen factories don't control deck height all that closely and some blocks might be significantly taller than other ones. If you cut too far you'd have to use a gasket from Cometic to jack the heads back up again.
Old Dec 10, 2021 | 01:04 PM
dogdays's Avatar
dogdays
Decking the block to get the deck square with the crank centerline and at 90 degrees from the other deck is a great idea.
Detroit machine work wasn't intended for race engines, rather for grocery getters and family vacation haulers.
Decking the block to get the piston closer to the deck will cost you surprising amounts of money, unless you own the shop.
I'd suggest keeping the stock or blueprint deck and spending the $$$ on Tim Meyer's pistons. UNLESS YOU ARE INSTALLING CLOSED CHAMBER HEADS!
R.
Old Dec 10, 2021 | 01:07 PM
DaveMcLain's Avatar
DaveMcLain
R.
I've had blocks where one side was .020 higher than the other side how well do the pistons work out in that situation?
Old Dec 15, 2021 | 07:13 AM
manicmechanic007's Avatar
manicmechanic007
A good machinist is always going to want to deck the block about 10 thou at least
If you go much more than that is when you run into manifold bolts not fitting and lifter preload being incorrect
The lifter plunger will no longer be in the center of the bore
Do it
More compression
More power
Snowymountainman
Montana Chapter
Apr 9, 2011 02:35 PM
bobbd
Jan 22, 2004 09:26 PM
grclark351
Jan 12, 2004 11:00 AM
Hunt-with-a-bluetick
18
Nov 18, 2003 05:32 PM
GT40man
Aug 11, 2002 08:47 PM
