Decking 400
Old Jan 21, 2004 | 12:52 PM
bobbd's Avatar
bobbd
Decking 400
How deep can you safely deck a 400 block?
Old Jan 21, 2004 | 01:57 PM
bubbaf250's Avatar
bubbaf250
The service limit listed in Ford docs is 0.0565", which puts the '75-up OEM stock piston at zero deck clearance.
Old Jan 21, 2004 | 02:26 PM
beartracks's Avatar
beartracks
The stock 400 piston will set "way" down in the cylinder. At least .250. It's much higher on the 351M. If you go past .030 total on heads and deck you may have sealing problems on the intake manifold unless you compensate it's sufaces.
Old Jan 21, 2004 | 03:37 PM
Torque1st's Avatar
Torque1st
Posting Legend
.250????
Closer to .070, then if you deck the block .010- to clean it up it goes to .060
Old Jan 21, 2004 | 05:02 PM
kopfenjager's Avatar
kopfenjager
do the stock 75 up pistons have a dish or are they flattops that sit lower in the bore?
Old Jan 21, 2004 | 11:38 PM
bubbaf250's Avatar
bubbaf250
All OEM 351M and 400 pistons were dished.
BTW: For some time, the '71 400 was said to have flat-top pistons, which explained its higher compression ratio and power rating, but the original pistons that I pulled from a 1971 400 had a very slight dish (about 4.5 cc).
Old Jan 22, 2004 | 12:50 AM
kopfenjager
I suppose if we deck the block enough to get quinch with the stock pistons, that the compression ratio would be to high. Can u even get quinch with the open chamber heads?
Old Jan 22, 2004 | 09:30 AM
bobbd's Avatar
bobbd
Thanks for the info, that is exactly what I was looking for. I want to shave heads/deck to come up with 8.7/8.9 to one compression. As I understand it, anything over .020 and the intake needs machining.
Old Jan 22, 2004 | 02:03 PM
Torque1st's Avatar
Torque1st
Posting Legend
You can not get quench with the open chamber heads.
Old Jan 22, 2004 | 03:56 PM
kopfenjager
Thats what I thought.Thanx
Old Jan 22, 2004 | 09:26 PM
74 F100 351m's Avatar
74 F100 351m
I took out .107. .035 off the bock amd .072 off the heads. NO problem gitting it to seal. BUT it will not run on chep gas. And I'm running 351W push rods to keep valve trane lined up right.And if you deck the heads DO NOT cut on the intake, take the same amount off the intake side of the heads. This way the intake will wark with other heads not just that set. My piston set in hole at .006. Just my 2 bits.
