Injector Stiction
Old Oct 22, 2021 | 05:16 PM
1L243's Avatar
1L243
Injector Stiction
I have never used a oil additive should I be using a oil additive for injector stiction?
My truck is a hard start if left out in the cold. I have replaced the glow plugs a couple of years ago.
Old Oct 22, 2021 | 06:05 PM
Gaugepro's Avatar
Gaugepro
The 7.3 injector does not have a spool valve, so no stiction so to speak.
Your injectors are worn, assuming you have verified that the glow plug relay is working. Lots of oil additives can mask the issue of worn injectors but in the end, that is the cause of your starting issues.
Old Oct 23, 2021 | 01:11 PM
Bitterroot Diesel's Avatar
Bitterroot Diesel
Former Vendor
Oil additive can also increase oil side longevity, but you probably have 200k+ on your injectors and it's time to swap them out. It would also be good to check other things like electrical, fuel pressure, compression etc.
Old Oct 24, 2021 | 01:07 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I would not recommend any oil additive. But I totes recommend synthetic oil to help tired injectors keep clicking in their golden years.
When synth is not enough, time for new injectors.
BRIAN NORCAL
Oct 30, 2017 05:26 PM
Tanyr Patt
Dec 2, 2013 08:22 PM
Visseroth
Jul 23, 2011 07:05 PM
WA.Ranger
22
Mar 15, 2009 09:27 AM
jwhite1993
24
Feb 8, 2009 10:30 PM
