EBPV questions
Old Oct 22, 2021 | 03:39 PM
BWST's Avatar
BWST
Got Data?
Very easy (assuming you aren't fighting rust, darn it!) I just did it - you can. GTP38 360 rebuild kit from Riffraff. Instructions attached.
My rebuild info below.
https://www.ford-trucks.com/forums/1...l#post20100730
I would think you could remove the turbine housing and EBPV outlet as a unit. I'm not sure why the instructions say to remove the EBPV - might just be for ease of removal of the turbine housing due to weight, or for cleaning?
Old Oct 22, 2021 | 07:39 PM
kefrko's Avatar
kefrko
Originally Posted by BWST
I would think you could remove the turbine housing and EBPV outlet as a unit. I'm not sure why the instructions say to remove the EBPV - might just be for easy of removal of the turbine housing due to weight, or for cleaning?
from the videos I watched I think you’re right. Unfortunately those bolts are a little better than the others but still pretty rusty. I’m soaking them in PB blaster overnight and I’ll try again tomorrow but might just need to put this one back together and upgrade the turbo when this one goes.
Old Oct 22, 2021 | 08:08 PM
BWST's Avatar
BWST
Got Data?
The shaft should have very little play, maybe just a bit side to side (don't want the wheel to touch the housing), and pretty much no detectable in and out movement (which would indicate a worn thrust bearing). If that's all good, you'd be fine to just change the compressor wheel and run it.
Mine was in good shape, but I rebuilt it because I was into it with 270K miles.
Old Oct 22, 2021 | 08:20 PM
Wes444's Avatar
Wes444
I had to mount my housing in a vice, and used a 1/2" breaker bar reduced to the 12 point socket. My housing and bolts weren't "rusted" , just light surface rust. Once initially and carefully broken free I grabbed a 3/8" ratchet.
It might sound counter intuitive, but try tightening the bolt and then loosening it. Once you get a tiny amount of wiggle spray your penetrant in when loosened so it can work it's way in.
Old Oct 23, 2021 | 03:39 AM
kefrko's Avatar
kefrko
I’ll give it a shot. Thanks
Old Oct 23, 2021 | 06:05 AM
RacinJasonWV's Avatar
RacinJasonWV
Sometimes a sharp hit with hammer and punch on the head of the bolt will free them up. Or at least allow the PB Blaster to get in and do its work.
Like BWST said, it’s ok to run it without a rebuild as long as it’s not loose. The reason I mentioned the rebuild is because I did just the wheel then wished I’d have rebuilt while it was apart. I didn’t have any issues but was still a regret so just trying to save you from the same. It sounds like the attempted rebuild may be more trouble than leaving it if there’s no signs of a rebuild need.
MountainManRobb
22
Dec 30, 2020 12:09 AM
B-Rad88
82
Jan 22, 2018 06:51 PM
Sous
16
Mar 9, 2015 07:56 PM
Roamineye
Apr 4, 2006 01:29 PM
yellow401
Mar 1, 2006 11:10 PM
