Starter replace/upgrade
Old Oct 20, 2021 | 08:56 AM
lah2420's Avatar
lah2420
1971 f100 360, 3 speed manual tranny, stock exhaust.
That being said, I plan on pulling the motor to have rebuilt this winter. Current starter seems slow to spin motor, even with new battery. I know I am used to the new high torque starters on newer vehicles, so I understand you can't compare a '71 to a '20. What is a good upgrade to the stock starter or is it best to stay with it? Hope I didn't just open a can of worms here.
Old Oct 20, 2021 | 10:14 AM
Lahti35's Avatar
Lahti35
What's the condition of the battery cables? What gauge are they? Could be dirty connections, small cables restricting current flow, or a bad starter also. Have you tried pulling the starter and hooking it directly to a battery with jumper cables to test it? I've had good luck over the years switching battery cables to something heavier than stock, I like to use 00 gauge welding cable as it's very pliable. I can get a stock starter to turn over like a house of fire with heavy cables. Currently my '68 has the original factory cables and turns over slowly, sounds like it's got a weak battery, cables are dinky... they look to be 4 or 6 gauge. I'll be changing them out asap. Current needs a certain diameter cable to flow efficiently, a bigger cable won't hurt performance but cables too small will. I must say I was surprised at the small diameter of the stock ford starter cable on my '68!
Old Oct 20, 2021 | 08:17 PM
Eric Hamilton's Avatar
Eric Hamilton
Agree with Lahti35, check all connections and grounds. Adding a ground from the engine block to the frame doesn't hurt either. If the starter is indeed bad, there are plenty of replacement options that won't break the bank compared to the price of new starter for a 2020' truck lol.
Old Oct 21, 2021 | 10:03 AM
lah2420's Avatar
lah2420
Cables did not even enter my mind. Pretty bad on me after being someone who fought with the company for 40 years about batteries and cables when installing high power two way radios. I bet they are the little Autozone cheapies.
As far as the cost of a 2020 starter, i stll have 4 years of warranty to cover that one. There isn't anything cheap on a new vehicle these days.
Mikecasino84
19
Aug 8, 2020 02:34 PM
Tim J
Sep 13, 2014 03:58 PM
JoeKramer
16
May 7, 2011 03:10 PM
hollenjoe
Nov 2, 2008 10:41 PM
burny1
Sep 19, 2002 04:11 PM
